F5X -- the EUVL Approach
Old 3rd November 2011, 09:09 PM   #561
qusp is offline qusp  Australia
qusp's Avatar
looks good, man those are some serious output PTH!!! what are you looking to solder the output wiring with an arc welder? what awg is that? 1|0?
Old 3rd November 2011, 09:10 PM   #562
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I hope he's well ..... or well and busy .....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 4th November 2011, 05:18 AM   #563
EUVL is offline EUVL  Europe
I specified 4mm holes.
For the middle hole, I recommend using a M4 brass standoff plus brass screws and nuts to connect the main PCB, daughter PCB and Gnd wiring to the regulators and input XLR.
For the speaker outputs, you may use the same, or consider using 4mm copper tubes as output connectors.
As to soldering, according to my experience, there is no problem if you have a hot iron say 100W, even using lead free solder. Preheating the PCB in an oven to 80C would also help, but not essential.
Patrick
Old 4th November 2011, 04:44 PM   #564
qusp's Avatar
aaah yes ok that makes more sense. i wonder if anyone makes copper standoffs? brass hmm i'm silly like that; i'd probably just use it like that till tweaked and replace with copper soldered. it wasn't so much the gauge that worried me, but the combination of gauge and being the centre of a pretty chunky ground plane and output ...ermm..trenches (trace just doesn't quite say it) that can suck the heat out of the iron as quick as you can give it. preheating the pcb would help.
looking good though; it takes 'low impedance ground node' to a whole other level
Old 4th November 2011, 06:43 PM   #565
I am sure if you pay a visit to your local jewel maker, he'd be most happy to custom make a few for you in 999999 pure silver.
Patrick
Old 4th November 2011, 06:47 PM   #566
qusp's Avatar
nope, just copper for me if anything. although as you say it would probably be easier to find someone to make one from silver. I suppose i could use one of the online short run CNC fab sites popping up around the place.
also perhaps the amphenol buss headers would fit. then i could get SPC 70-140A capable connection radsok headers. i actually think they will fit. i'll dig up a link
something similar to this power block connector. but pretty sure there is one without the surrounding pins that you press fit.
though thats starting to get a bit carried away =)
Old 4th November 2011, 07:11 PM   #567
Studley is offline Studley  United Kingdom
Patrick
Patrick
Have I misunderstood? Do you mean use Copernicus pipe as the actual connector that you attach your speaker cables to? If so, how do you attach the cables to make a good connection?
Old 4th November 2011, 07:14 PM   #568
Ha! Bl**dy predictive text, should say copper of course
Old 4th November 2011, 07:33 PM   #569
qusp's Avatar
haha copernicus, indeed (stupid thing changed it to heat? wtf?) the predictive text here is actually getting on my nerves lately.
no what he means is copper tube to connect from board to chassis mounted connectors of your choice and i believe at least the GB have speakon and bayonet? speakon at least.
aayarrrrgghhhh so sick of having to go back and correct the stupid browser's 'corrections' its a forum engine thing isn't it? because its different with different forums and there is no way to change settings. we use so much jargon here that its incredibly frustrating
Old 4th November 2011, 07:35 PM   #570
Yes I suspected as much but was kinda hoping he had come up with a cheap cool way to replace terminals
F5X -- the EUVL ApproachHide this!Advertise here!
