#501 |
Your heatsinks are all wrong.
At low current ie 10R (60mA) nothing will cook, but if you are HOTRODDING you will need to reorientate your heatsinks. Last edited by KatieandDad; 22nd April 2012 at 12:29 PM. |
#502 |
One other thing to check is that you haven't got any hairline shorts around the B1 buffer section.
OK my PCB was homebrew but I had minute shorts around the relay. That is why I decided to use the Salas Shunt Reg on its own with a regular B1 PCB. |
#503 |
diyAudio Chief Moderator
The Mosfets don't make full contact on the sinks in the picture! Dangerous.
#504 |
For the (L) offset the problem can be a dead JFET or wrongly matched by much in the right hand horizontal pair on the pic.
#505 |
The output offset depends on what you feed into the DCB1 and on what the operating Id is, in comparison to the measured Idss of the amplifying jFET. It does not depend on the PSU voltages. It does not depend on the LED voltages. It does not depend on the CCS current.
Why have you braided your cable pairs/triplets for high inductance? Twisting for low inductance, is much preferred for attenuating interference. Last edited by AndrewT; 22nd April 2012 at 02:04 PM. |
#506 |
Thank you for your answers and for your recommendations.
At first I will remove it out of the case (I didnīt expect problems ...) and will check and measure all the things you mentioned. @Salas I disconnected the heatsinks cause I thought it effects something. I know they are oversized and will remove them. Andreas |
#507 |
andreas, I don’t see any thermal grease applied, I would recommend to apply some.
#508 |
#509 |
Its very good. Are the supply voltages still alright? Check that you got 1.5-2VDC drop on the current set resistors too. Then you are good to play.
#510 |
I measured 1.6VDC and itīs connected to Symasyms and sounds good at "Plastic Speakers" in the celler.
I have to finish the front plate and than it moves to my second setup which is DCB1, Symasym, Pearl (my first is ONO, Aleph P1.7, Aleph J :-). I will post some pictures later. Thank you very much for your help! Andreas |
| WTB Mezmerize PCB | 3GGG | Swap Meet | 3 | 16th January 2011 09:15 AM |
| FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed | korben69 | Swap Meet | 13 | 17th May 2010 12:56 PM |
| My XXLS Subwoofer building thread... | harrisni | Subwoofers | 9 | 28th October 2007 08:21 PM |
| Fave song from SOAD 'Mezmerize'? | PeteMcK | Music | 6 | 8th March 2006 03:12 AM |
| Gainclone building thread based on BrianGT's boards | meat | Chip Amps | 752 | 8th August 2004 06:25 AM |
