Mezmerize DCB1 Building Thread
Old 3rd March 2015, 02:06 PM   #1521
R.I.P.
Originally Posted by Joel Wesseling View Post
...................Looking for Matched quads of 2SK170-BL.
How many pieces would I need to buy, to come up with 2 matched quads?
I see 50 Pieces for $33 and 20 for $13, on ebay..
I measured many hundreds of lsk170.
I found lots of matched pairs which I sold on at low cost. All the b grade are sold. I still have a grade and c grade in swap meet.
But I did not find any matched quads.
Matching requires both Id and transconductance to be equal.
This is a very sensitive measurement and the chances of getting a quad set seem by my experience to be very low (zero quads from 300pairs)
However,
if you are ONLY selecting by Idss and completely ignoring gm, then it is very easy to select by Idss, so easy it is recommended regularly and by many to DIY.
You don't need to pay the exorbitant prices I see being asked for selected Idss pairs.
Out of a batch of 100 devices you will get at least 40pairs to better than 1% of Idss. The remaining pairs are likely to be better than 5%
= virtually no wastage.
regards Andrew T.
Old 3rd March 2015, 10:08 PM   #1522
Dennis Hui is offline Dennis Hui  Canada
Originally Posted by Salas View Post
Lower THD due to higher Yfs and narrower bandwidth due to higher Ciss. About DC offset, matched Idss criterion stands the same although such high Yfs JFETs tend to be even more temperature susceptible than K170.
Thanks for the info Salas! I'll stick with 2sk170.
Dennis
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 9th March 2015, 07:06 PM   #1523
zibra is offline zibra
New owner here. Which resaistors exactly got most influence in sound? how many of them are most important?
I found 4 at output but see 8 of them
http://www.audiocircle.com/index.php?topic=85001.0
Old 9th March 2015, 07:54 PM   #1524
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The 220 Ohm ones are the more influential. Found in two pairs left and right to the output relay towards the PCB's center.
Old 9th March 2015, 08:08 PM   #1525
220R you meant? Next are 220k and least important 1M?
Thank you. In that case Ill try 4x220R and see if I hear difference first.
Is there any tolerance of value? Can I use 200R or 180R?
Old 9th March 2015, 08:28 PM   #1526
Salas's Avatar
The front row pairs near the PCB's edge flanking the signal output connector have two 220K and two 1Meg ones. Those are in parallel to the signal and less important. The 220R (Ohm) ones are in series to the signal, hence more important. All in all those eight are the only ones related to the L & R signal paths. You can use 200R instead of 220R.
Old 9th March 2015, 08:30 PM   #1527
Superb, thank you for explanation. Ill try Caddock first.
Old 9th March 2015, 08:32 PM   #1528
Salas's Avatar
Alright. What type of resistors you got there now? Have you listened to it already and in what kind of system?
Old 9th March 2015, 08:41 PM   #1529
Im not in hurry yet Just info for future.
Bought it assembled already and it looks like Takman metal film resistor.
DCB1->renovated Dynaco ST35->DIY speakers ScanSpeak 2608/913000 + Visaton AL130
Not ready now for changes though.
Old 9th March 2015, 08:48 PM   #1530
Salas's Avatar
Consider sinking the MOSFETS for manning it up to 200mA at a point also.
Mezmerize DCB1 Building ThreadHide this!Advertise here!
FS : F3 PCB + PSU - Hypnotize - Mezmerize - LightSpeed korben69 Swap Meet 16 21st June 2013 06:52 AM
WTB Mezmerize PCB 3GGG Swap Meet 3 16th January 2011 09:15 AM
My XXLS Subwoofer building thread... harrisni Subwoofers 9 28th October 2007 08:21 PM
Fave song from SOAD 'Mezmerize'? PeteMcK Music 6 8th March 2006 03:12 AM
Gainclone building thread based on BrianGT's boards meat Chip Amps 752 8th August 2004 06:25 AM
