Mezmerize DCB1 Building Thread
The relay is passive and the BC transistors are its coil drivers not belonging to the audio circuit. What relay type number you used? Are those JFETs measured for IDSS and matched by you? Where did you get them? Can I see a close up photo of one? Clean the board's solder side thoroughly with alcohol also.
I matched them myself
You think it's just with the jfets? Cause I can order from DIYAUDIO guys.
When the supplies give right rails only the JFETs signal quad remains to fault. Either to be faulty or grossly mismatched. IDSS is inversely proportional to RDS. Cross check your IDSS matching vs Ohm measurement between D & S. Matched JFETs should not measure different for RDS Ohm.
