Modified Dual Differential F5
1st try was CheffDeGaar's version, second try was the version with IRF-MOSFETs. Here is a link to some posts regarding my version with IRFs:
http://www.diyaudio.com/forums/pass-labs/143128-ugs-problem-3.html#post1950135
IMHO, the actual version sounds better then the second and the first try (maybe due to the low open loop gain and the low harmonic distortions compared to the others). Otherwise I would use one of the previous versions.
Drawback: the MOSFET-based versions have a poorer DC offset stability.
Uwe
Just looking at the irf version schematic. It seems you don't have any gate resistors.
I didn't read the whole thread so appologies if I am stating the obvious.
Forget this schematics, I used them only for simulations. Of course I use gate stoppers on the real pcbs.
Here is a picture of the UGS with IRFs. Unlike the UGS with Toshibas this version has only single ended inputs (the inverted input is shorted to GND on board) and an additional Alps pot for volume control (at the output). It's still working.
