Hello, quick and stupid question here. I have the Pass board, and the recommended PEC 25K linear pots. They are installed upside down, so that the solder tabs stick up.
Looking at the board, each channel shows cw,ccw and w. Which hole goes to which tab? There are no markings on the PEC pot or tabs that I can see. Thanks for any help on this simple question. Now for a really stupid question. What does cw,ccw and w stand for? Only thing I can think of is clockwise, counter clockwise, and whatever w stands for. There. Russellc Last edited by Russellc; 5th July 2010 at 03:47 PM. |
#2 |
Wiper. The connection to the moving contact
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#3 |
Gottcha. Thanks for the hyper fast answer! You wont believe how long I thought about it before I asked this question and exposed my total ignorance on the world wide web.
Can you tell me which is the wiper? I assume the one (usually center) that varies as the pot is turned? If so, does it matter which the other 2 are connected to as long as both pots are wired the same, or it isnt that simple?Russellc |
#4 | |
"This is DIY. I view op amps the same way I look at a can of soup or a fast-food burger" NP |
#5 |
uughh???
#6 |
Usually the ones I play with have a little picture on the side.(Worth 1000 words) Yes it matters. Signal will be increasing when you want it to decrease, when it's bassackwards...
#7 |
When looked at from the front the right hand pot connects as per the board left to right; whilst the left pot the outer two wires cross over to the outer connectors on the PEC.
#8 | |
Russellc |
#9 |
#10 |
| FS: Conrad Heatsinks;.... 'PASS' B1 boards w/JFETS;...... F4 AMP & PSU boards | cowboy99 | Swap Meet | 5 | 25th August 2009 02:39 AM |
| TDK vs. Alps vs. PEC pots | chuck55 | Chip Amps | 4 | 31st May 2009 07:05 PM |
| Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips | analog_sa | Swap Meet | 4 | 14th March 2009 05:29 PM |
| Pass Pearl PCB help! Are these boards OK? | argyris | Pass Labs | 3 | 4th September 2008 06:41 PM |
| FT: Pass boards for P101 boards | bjefferys | Swap Meet | 1 | 26th March 2006 07:39 PM |
| Page generated in 0.12493 seconds (77.12% PHP - 22.88% MySQL) with 11 queries |
