Pictures of your diy Pass amplifier
Old 25th July 2012, 04:04 PM   #1301
yoke is offline yoke  Croatia
yoke's Avatar
It's fischer elektronik SK41
They were like 15-20Euro a peace, rated at 0.28K/W for 150mm...by they spreadsheet..but it turns out to be more like 0.5 ...but still it was good buy
I buy them localy,in Croatia
http://www.mikrotrend.com/PDF/akcija.pdf
Old 25th July 2012, 04:10 PM   #1302
yoke's Avatar
Originally Posted by vdi_nenna View Post
Nice, Yoke! How did you finish the metal case?
I don't know is this the right word on english - eloksation / anodization ?
Heatsinks in black the rest of case in some sort of gray
Old 25th July 2012, 04:13 PM   #1303
AudioSan is offline AudioSan  Norway
well. for that price, it is a lot of cooling for the money ayways
0.28K/W is for 70-80C rise. that way the can look better on paper
Old 25th July 2012, 04:14 PM   #1304
vdi_nenna is online now vdi_nenna  United States
vdi_nenna's Avatar
Pictures of your diy Pass amplifier Send a message via Yahoo to vdi_nenna
anodization
Yep, anodized.
Thanks.
I build, therefore I am.
Old 25th July 2012, 04:25 PM   #1305
yoke's Avatar
Whell they go for 62-65* in summer...
4 of them is good for stereo Aleph 30...
But was not enough for Aleph X
Old 25th July 2012, 04:28 PM   #1306
R-K Rønningstad is offline R-K Rønningstad  Norway
R-K Rønningstad's Avatar
Yoke - fantastic amplifier!
Old 25th July 2012, 04:36 PM   #1307
if one use 3 pc pr side. it is down to 0.16C/W pr side. given 0.5C/W pr pc.
that will do for alephX and aleph2
Old 25th July 2012, 04:53 PM   #1308
yoke's Avatar
Thanks all for kind words
My Aleph X is on +/-20V and I have 4mosfets per side, 8 per channel...giving like 60W on 8Ohm...
I have forgot all the data, because it was long ago..there was some spreadsheet to calculate voltage, mosfet dissipation, over desired wattage.
Don't know, but I think I have like 1A on mosfets...
so the bank of 4mosfets were dissipating like 75W and it was to much for one heat sink as it gets like 65* in winter...
I could run some air over it...but didn't
I change concept and decide to build some active loudspeakers and use aleph to drive drivers
here are one picture of loudspeakers in background ..don't mind the PC in front
(by the way...this is newer ending proces..ggrrrrrrrr)
First I tought to drive bass driver with Aleph X (as it was already build) but it doesn't make sene to use A class for it...
Old 13th August 2012, 02:36 PM   #1309
c_door is offline c_door  Italy
Default My F5 monos
Hello,
here you go the pictures of my F5 monoblocks.
Heatsinks by Gorini Dissipatori. Model 7078/200, and 5306/100 for the diode bridges.
Copper and alu parts from a local locksmith, very unexpensive.
Trafos by Toroidy.pl. 300VA audio grade.
Had to use an unofficial PCB because of the form factor.
Mosfets matched by Hannes (h_a on this forum). Thanks Hannes !
Front panel is a stone slab with a onyx eye, backlighted by a led.
Mills and Holco resistors from hificollective, other stuff from Mouser.
With two CL60 thermistors in series with the trafo's primary, I don't get any bump at power on.
The signal path is very short. The amplifiers run dead quiet, with no hum or buzz. Temperature of the heatsinks is about 42C with a 0,590V bias.
A perfect match for my pair of Troels Gravesen's DTQWTs .
Many thanks to diyaudio for all the info, and to mr. Pass, the one and only.
Cheers. Carlo
Old 13th August 2012, 02:39 PM   #1310
Default My F5 monos
Some more "porn" ..
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
