Pearl Two - Page 216 - diyAudio
Old 6th May 2013, 09:14 PM   #2151
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by merlin2069er View Post
Problem is, I don't own a turntable or any records.
That's nothing that an application of proper funding can't fix...
Old 31st May 2013, 08:04 PM   #2152
Siberia is offline Siberia  Lithuania
Siberia's Avatar
V
Old 10th June 2013, 11:19 PM   #2153
kop89 is offline kop89  United States
Would it be a problem if I am using a yellow LED (voltage is around 1.95V)? I have just noticed the build instruction specifies red LED.
Thanks!
Old 11th June 2013, 03:21 AM   #2154
Default Red vs Yellow Led
the voltage across the led sets the bias of the stages, so yes it would matter. Not harmful bad, but it changes the bias of your output stage, which he, Wayne, designed to be 1.7v or really close. mine is close to 1.8 and it sounds like heaven, so maybe if you listen then change you could see which you like.
Bias does change the sound in my experience. Hope I helped. enjoy
John
Old 11th June 2013, 06:43 AM   #2155
omishra is offline omishra  India
I purchased 10 number of Red LED. All measured voltage drop from 1.65-1.90V. So I choose close match 1.8x range, sounds good. No problem though I can more current P1 for zero output offset.
Old 11th June 2013, 02:35 PM   #2156
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Having measured literally thousands of red LED's, I have never found any under 1,8V...
Can anyone please document what type-no that is close to 1,7V?
AND where to get them???
Arne K
Don't believe everything you think...
Old 11th June 2013, 06:34 PM   #2157
Arne K
Okay - then maybe there's not much sense to desolder the yellow LED from my board
Can anyone possibly give their wisdom on this matter?
Old 11th June 2013, 08:09 PM   #2158
DIY !
Cobra2's Avatar
If the voltage-drop is ok, I do not think you ever will hear the color....
Arne K
Old 11th June 2013, 08:21 PM   #2159
Arne K
Filtering for "red" and forward voltage "1.7V" leaves 271 parts in the Digikey category LED Indication-discrete. Quite a few of them are normal axial types and in stock.
BTW I have Panasonic part P605-ND (Digikey) in mine with a forward voltage of 1.8. Never crossed my mind to match them. What happens if the bias is a bit higher? Higher gain? Measured voltage drop is between 1.6 and 1.7V, so I guess I'm OK.
Old 11th June 2013, 08:24 PM   #2160
6L6's Avatar
You guys are talking about a bias device in a Constant Current Device. If the voltages all around the schematic are good, whatever LED you have is doing a great job!
Stop worrying about it and buy more vinyl -- I found some great stuff today.
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
