Pearl Two
Pearl Two
Old 17th January 2018, 06:24 PM   #2881
canute is offline canute  Denmark
Originally Posted by 6L6 View Post
Tin Whiskers -
An easy way to stop that? Leaded solder...
Are there any "best alloys" for our purpurse?
Old 17th January 2018, 06:48 PM   #2882
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
Yes - leaded solder. The lead stops that from happening. 60/40 rosin core is fine. 63/37 also.
Lead-free solder sucks.
My favorite solders are
Kester "44" It has a TON of rosin flux. Makes really, really nice joints and flows better than anything I've used, due to the flux. Joints have a bit of a fluxy mess on them, but worth it.
Cardas Quad Eutectic - A 4-metal blend, mainly Tin and Lead, but with a couple percent of silver and copper as well. Low melting point, good flux, very easy to desolder. The silver is there not for any audiophile reasons but because silver plated contacts and wire will whisker and corrode in presence of non silver-bearing solder. The Cardas Quad is allegedly the same recipe that the Bell Telephone system used, where longevity and reliability was paramount.
Old 17th January 2018, 08:17 PM   #2883
MASantos is offline MASantos  Portugal
I bought a big roll of cardas solder a long time ago and it is great to work with. I have an 12 or 13 years old headphone amp with solder joints looking as good as new!
Old 18th January 2018, 12:16 PM   #2884
Eric is offline Eric  United States
Eric's Avatar
Pearl Two
Tin Whiskers -
Whisker (metallurgy - Wikipedia)
Sadly, this is something that I only recently learned when I visited the production line of an aerospace defense contractor. I guess they are used to people not asking too many questions because the president of the company did a double take on the shop floor when I asked him a specific question about the physical configuration of the regulated power supplies that were coming off the line
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 21st February 2018, 04:24 AM   #2885
Lbcyclist is offline Lbcyclist  United States
Hello All,
My first post on this thread. First, many thanks for the ongoing support and contribution to this thread, it makes a fascinating reading. Special mention to 6L6 for the build guide, patience and guidance, multiple others for the knowledge and expertise. And espcially to Wayne and Nelson for their support of DIYers.
I received my Pearl 2 boards and they are almost completely populated. One question I am debating is the resistive loading. I have currently an Ortofon with '10 Ohm or higher' recommended loading, but will have 2-3 more cartridges in the future, some mention 90 Ohm or higher.
I would like to avoid having to resolder resistors and therefore would like to use the solution mentioned in post 2717 of using a rotary switch in parallel to R19 [presumably using R20 holes?]. I have a 12 position MBB rotary switch I would like to use and thought I'd start at 7 Ohm and use a 1.4 factor to get to 320 Ohm at the last position [power of 2 series]. Does such a scheme make sense? Should I use different values? I know it's somewhat over the top, but isn't DIY all about pushing the envelope, or at least the wallet?
Old 9th June 2018, 02:15 AM   #2886
KevinHeem is offline KevinHeem  United States
KevinHeem's Avatar
Pearl Two
Since it doesn’t come in kit form, I had to buy a preassembled XP-15...WOW! That’s all I’ll say about that.
However it gives me perspective on the Pearl II which is a great phono-pre in it’s own right. I’ve had a few really nice phono stages at home lately, and the Pearl II is playing in the same ballpark. The Pearl II has served me well and will go on to play beautiful music for someone else I’m sure. What a gift to the DIY community...thanks Wayne!
Old 9th June 2018, 10:30 AM   #2887
Wellerman is offline Wellerman
I would start a little higher, I think there are not that many cartridges that need a 7 Ohm loading. Medium output mc's (that go well with the 55dB gain of the Pearl II) like a loading of aroud 400 Ohm - 1k or something like that. Starting at 33 Ohm will get you to around 1k3 (50 -> 2k). I would also consider leaving one position on the switch unoccupied which would get you 47k for high output mc's.
I've got a slight rebuild of my Pearl planned where I use dipswiches for gain, capacitance and resistance. The ability to parallell more resistors gives you lots of loading options.
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
