B1 Active Crossover
B1 Active Crossover
Old 3rd December 2009, 06:41 PM   #21
ljfont is offline ljfont  Canada
ljfont's Avatar
Nice.
Checkout
http://www.borbelyaudio.com/adobe/ae699bor.pdf
See Figure 15c and table 3. You can lower your THD even further, and reduce the DC offsets at the output.
However watch out for your XO impedances, they can introduce more THD than what you would want. Also, if you need higher XO frequencies, you may want to think about cascode to reduce input capacitance.
Leo
Old 3rd December 2009, 09:06 PM   #22
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
B1 Active Crossover
Also check out the Xenover Ver. 2.0 Article By Grey Rollins.
Very nice.
Gravity - Making the G since 13.7 billion B.C.
Old 4th December 2009, 12:40 AM   #23
udailey is offline udailey  United States
Passive Aggressive
B1 Active Crossover
Default My Shot at a PCB`
Whipped this up. Was thinking of putting all resistors in a ladder formation and the 2sk170's side by side in pairs then in a ladder as well. Might try that and see how it goes but here is my first try.
This is optimized for space and for Dale 1/4W resistors or smaller. Larger resistors would work but more than 1/2W might be trouble. I imagine PRP would be fine.
This is double sided. Single sided is a pain with the power lines needing to be so close.
---What I am not sure about here is whether the caps and resistors are going to a ground or to B-...?? I see that the sign for B- on the source of the 2sK's is the same as what I have interpreted as a ground on the caps/resistors.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 4th December 2009, 02:42 AM   #24
Jacques Merde is offline Jacques Merde  United States
Jacques Merde's Avatar
Uriah
Uriah,
My apologies for the not-so-clearly labeled schematic. This attachment should take care of that. Frankly, I didn't anticipate anyone posting a PCB layout this soon. It hasn't even been breadboarded yet
I'm having a little trouble following your board layout. I don't see the connection from the input and output buffers (Q1, Q2, Q5, Q6, Q9 and Q10) to B-. I also do not see a signal connection from the input buffer to the HP and LP sections.
Jacques
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 4th December 2009, 02:59 AM   #25
And here is a frequency response plot showing the improvement in stopband attenuation of the LP section. The original is in post #4.
Old 4th December 2009, 03:00 AM   #26
The same plot with an expanded y range:
Old 4th December 2009, 09:23 AM   #27
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
B1 Active Crossover
Originally Posted by Jacques Merde View Post
Uriah,
Jacques
I think there is a lot of interest Jacques, and don't be surprised if someone else already has!! I'm certainly thinking about starting to work on a verro board layout The Spice sims look very promising, and I'm rather intrigued by your solution to the stopband response problem , though the sim certainly shows it does the Trick!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 4th December 2009, 09:38 AM   #28
R-K Rønningstad is offline R-K Rønningstad  Norway
R-K Rønningstad's Avatar
I was planning to re-do my X-over with B1 circuitry. That is the Linkwitz x-over with LR2 and dipole compensation etc.
Old 4th December 2009, 09:41 AM   #29
pheonix358 is offline pheonix358  Australia
pheonix358's Avatar
Hi all, this looks like just what I need as well. Could you post the formulae for the RC values for those of us that are challenged? Additionly I assume this is a unity gain. If so can the gain be increased.
Thanks in advance.
Terry
What we don't understand is called magic.
Old 4th December 2009, 12:16 PM   #30
R.I.P.
This a 2 pole (12dB/oct) LR filter at 700 Hz. It should be fairly straightforward to implement 24dB/oct.
the 2pole (-12dB/octave) has Q=0.5 to create the L-R function.
A 4pole using two cascaded sections of 2pole requires both sections with Q=sqrt(2). two cascaded Q=0.7071 gives an overall Q=0.5
This is the normal Butterworth roll off and needs the feedback components doubled up to create R & 2R in both the HP sections and C & 2C in the LP sections.
regards Andrew T.
B1 Active CrossoverHide this!Advertise here!
MOX - active crossover moamps Analog Line Level 242 3rd March 2017 07:14 PM
MOX active crossover buy tiroth Group Buys 262 11th September 2014 08:24 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
