Pass "DeLite" Amp from BAF
Old 4th May 2012, 08:10 AM   #791
Spooky Electric is offline Spooky Electric  Germany
Spooky Electric's Avatar
I'm very curious how this is going to evolve. How about the other usual suspects: IXTH6N50D2 and SJDP120R085?
Old 4th May 2012, 11:23 AM   #792
Pano is offline Pano  United States
Pano's Avatar
Sure, you could use other MOSFETs. They don't even have to be depletion mode, they just have to be biased properly to drop the same voltage as the resistor or bulb.
One problem I'm finding is thermal - it takes some time to settle. Until the temperature settles, the DC offset drifts. That's not good for the speaker. The amp will probably need some sort of DC servo or DC protection circuit - and that's going to be about 5X more complicated than the amp. We shall see.
Take the Speaker Voltage Test!
Old 6th January 2013, 07:12 PM   #793
Pano's Avatar
I finally got back to this after a busy year. Now trying with Nichrome wire in place of the light bulb. I'm attempting a low voltage version.
These IXTH20N50 sure do seem to need a lot of bias current to get any decent voltage swing. As anyone else found the sweet spot for bias?
Old 27th February 2013, 01:01 AM   #794
siruis815 is offline siruis815  United States
Pano - I really need to come up and audition some of your stuff and take a look at your delite amp. I keep coming back and looking at this amp as a future build (too many project right now).
In any case, since I have nothing really to add to this thread - Good luck!
Ben K.
Old 3rd March 2013, 01:55 PM   #795
diegomj1973 is offline diegomj1973  Argentina
diegomj1973's Avatar
Default DELITE improvements
Here is my small contribution: a new connection of C3, the speaker and the 0V terminal. This allows a great improvement in the ripple rejection, without altering any of the other sound settings.
Pass "DeLite" Amp from BAF-diegomj1973-delite-modification-gif
The improvement depends on the current and voltage of the circuit. The improvement also strongly depends on the resistance of the filament of the bulb.
Another thing I found is that if you choose a filament resistance equal to about twice the lower speaker impedance, frequency response is much flatter and pleasant. The impedance of a speaker tends to fluctuate between a minimum and a maximum value typically about 400 to 500%. Choosing a filament resistance equal to twice the minimum expected impedance value, ensures that the power dissipation in the speaker minimally varies between extreme frequencies of the spectrum.
I give an example: if the speaker impedance varies between 4 ohms and 16 ohms (between a frequency close to fs and about 10 KHz or more) and choose Rfilament = 8 ohms: Power at minimum impedance (about 200 to 600 Hz ) is only 0.51 dB greater than the power in a high impedance (near fs and 10 KHz or more).
Pass "DeLite" Amp from BAF-example-db-relative-vs-rfilament-zspeaker-gif
Unfortunately this leads to a lower efficiency and less control of the low end of the frequency.
regards
PD: Check the polarity of the capacitor C4 (depending on how you connect your preamplifier). R1 can be changed to the opposite side, if you want. The 0V connection can be left as in the original scheme, if you want, too.
File Type: gif Example of dB relative vs. Rfilament and Zspeaker.gif (32.0 KB, 557 views)
Old 3rd March 2013, 02:12 PM   #796
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I am little lost,
C3 seems to be of wrong polarity. C4 seems fine.
Also, the ground connection after PS would seem to keep the thing from powering up.
Old 21st March 2014, 04:43 PM   #797
OllBoll is offline OllBoll  Sweden
Soon when my R085 arrive (Thanks Tea-Bag!) I'll start building this little amp:
First I thought to use a single device per channel which should net me about 8-10 W into 8 ohm. I remember Nelson talking about that he likes to use these devices at 20-30W and since I will have enough JFETs for it I thought I could parallel two and do this:
Now I just need a sanity check if there is something dumb in the schematic =)
If I've understood correctly the degeneration works as output resistors so I won't have to add extra series resistance. My question is if there is any problems of both JFETs sharing the same current source which in my case is the big 193V inductor.
If this proves to be a bad idea then the plan is to use a single device like the second pic.
In the end the idea is to do 2x paralleled amps for the mids and then 2x single device amps for the tweeters, and those amps will have smaller inductors =)
EDIT: Though when you think about it's probably easier to just use one and push it to 40-45 W. If in 3 years one of them fails I still have 2 spares and when those also fail there will probably be a newer and more shiny transistor to use instead =)
Old 23rd March 2014, 01:42 AM   #798
Hmm, I think the 10k resistor & bias should be on the left side of the gate stopper resistor and not on the right. And when I think about it: As the R085s aren't perfectly matched then shouldn't it be better to have a cap to each of them so the bias of one can't leak onto the other one?
Old 23rd March 2014, 04:44 AM   #799
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
1) Naaah, it's fine.
2) Naaah, it's fine.
You can do it either way.
Old 23rd March 2014, 10:50 AM   #800
Nice!
Another thing I've wondered about dissipation and reliability:
If we take say the R085 or similar device and push it to 40-45W with generous heat sinking. Is it that you expect it to fail after say 5 years or is it that if you produce 100 amplifiers you expect a few of them to fail after say 5 years?
EDIT: I think I found you clarifying that a while ago: I take it this is true today too?
Pass "DeLite" Amp from BAFHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 03:28 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
