Old 25th October 2011, 09:55 AM   #761
Originally Posted by Puffin View Post
I used the IXTH6N50DN for these boards. I will re-build them and see what happens. I also have some IXTH20N50 chips and may make up some boards for those as well.
I wil report back in due course.
Rob.
I 've used mainly IXtH6N50D2 , and later the Power Jfet
Old 26th October 2011, 09:04 PM   #762
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Been following along on this thread and see that a CCS version of a simple 085 jfet amp has been built. Is the most recent schematic on page 61?
Haven't finished the Z9 yet and dying to build this one!
Thx,
Vin
I build, therefore I am.
Old 26th October 2011, 09:48 PM   #763
Thx,
Vin
The most recent schematic with R085 is here : Pass "DeLite" Amp from BAFBut I have
a new one , mainly becouse of the way the negative voltage has been apply from the original power supply, thank you Mr Pass for the ciruit . With lightbulb , with ccs of page 61 , or also a ccs with fixed current ( to be tested more ) where the -V at the gate decide just the Voltage operation of the circuit ( typical half -the rail ) and the current through the Jfet remains the same .
Old 27th October 2011, 09:22 AM   #764
Default New Schematic with R085 Power Jfet
Here it is , that is how I built it , for the ligth bulb version there are obviously some modifications in the Power Supply .
I left to the current source to be drawn since there are various permutations for it .
Enjoy .
s
Old 27th October 2011, 10:17 AM   #765
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Cool, I am dumb - this version allows you to tap off the PS to get a negative voltage I presume, without another bench supply?
What have you settled on roughly for negative gate supply voltage?
Old 27th October 2011, 10:24 AM   #766
buzzforb's Avatar
Originally Posted by Nelson Pass View Post
You can rig a "negative supply generator" off of your existing transformer.
Here's one.
Tea-Bag, Nelson posted this in one of my threads. It may help as well.
Old 27th October 2011, 10:27 AM   #767
Yes it does that .
The negative gate voltages varies , depending on the current source implementation , the voltages of VDD , and the current throug the Jfet .
Now with fixed CCS of 1,4 amps for example , VDD = 30 , Drain of the Jfet at 16 volts , the gate to ground voltage is - 3,5 volt
Old 27th October 2011, 10:30 AM   #768
yes , that is . Thanks again for the help :-)
Old 27th October 2011, 12:09 PM   #769
vdi_nenna's Avatar
As Mr Burns would say, "Excellent!"
BTW- The negative supply doesn't need to be high current, correct? It only needs to be a fraction of the Drain current, yes, no, maybe so?
Vin
Old 27th October 2011, 08:58 PM   #770
Vin
Little current , 1,3 mA
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 03:28 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
