Pass "DeLite" Amp from BAF
Old 15th March 2011, 03:42 AM   #601
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
If it's a depletion mode fet, then depending on the matching and
relative Vds figures the Gate may be negative with respect to the output.
Old 15th March 2011, 07:44 AM   #602
angcl is offline angcl  Singapore
Hi Mr Pass,
Stupid question from me again.
1) How many VA for T1 and what is the suitable VDS if i use "IXTH6N50D2"?
2) is the sound better than the bulb ?
Old 15th March 2011, 01:50 PM   #603
stefanobilliani is offline stefanobilliani  Italy
Great ! Infact in this case , not matching the D Fets , the gate to output voltages are -2 and -4 V.
Old 15th March 2011, 04:14 PM   #604
The one and only
My experience is that you can use an IRFP240 as the upper
transistor and save lots of money. To the extent that you
want a pure current source and can spare a volt, you can
raise the value of its Source resistor also.
Old 15th March 2011, 06:40 PM   #605
And it works . Thanks a lot . So I set R5 1,47 for now , if it is correct probably we can also rise the rail Voltage to 40 volts or so
Old 15th March 2011, 07:09 PM   #606
ra7 is offline ra7  United States
You are fast Stefano!
IRFP240 must drop at least 4 volts. What is your drain voltage and current draw now?
This is turning out to be a great little 'tutorial' amp.
Old 15th March 2011, 07:36 PM   #607
The current is the same , as set from the self-biasing D mosfet Q1 and is 1,6 A . Drain voltage at half the rail like before .
Old 15th March 2011, 07:41 PM   #608
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Great to have a definitive (for the moment) diagram.
Thank you Stefano (and goes without saying: thank you Papa too)
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 15th March 2011, 08:12 PM   #609
woodturner-fran is offline woodturner-fran  Ireland
I may have missed it, but what sonic difference does it make?
Fran
Old 15th March 2011, 08:20 PM   #610
Fran
Any ideal what is the output wattage for this setup ? same as before ?
Pass "DeLite" Amp from BAFHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Paging Mr. Pass, Mr. Pass pull my finger please. khundude Pass Labs 2 5th December 2008 04:11 AM
Pass Tharagard A75 vs Pass Aleph 1.2's daly41k Pass Labs 7 18th February 2007 03:10 PM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 03:28 PM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
