Old 19th October 2009, 11:29 PM   #1
rgheck is offline rgheck  United States
Default B1 Power Supply Options
I've built a B1, with which I am very happy, and it is currently running off two 9V batteries. But now I'm considering experimenting with some other power supplies, in particular, a regulated supply. I just happen to have an unused Hammond 182K30 sitting around, which gives 30V off both windings. Would it be possible to put this into some circuit to get what the B1 needs (18V) out of it? If so, could anyone point me at where I might find such info? If that's too big a transformer, can someone point me at a good design for a simple PS for the B1? I saw one thread on this, but it looked as if the person was having rather a lot of problems.
Old 19th October 2009, 11:37 PM   #2
R-K Rønningstad's Avatar
I bugh the nice and small Velleman K1823 for my B1. It has a LM317, rectifier diodes, and a cap. And a pot to adjust the output voltage.
I replaced the standard 1N4004 (or whatever it was) with some better ones. It only has 1000 uF, but the B1 itself has some capacity, and you can always add some external bulk as well.
At least it is a USD10 or so starting point.
Rolv-karsten
Old 19th October 2009, 11:40 PM   #3
BTW my Velleman with the same order number looked different, like attached here. No sweat anyway....
You can always replace the trim pot with a fixed resistor also.
File Type: jpg 84414150-7c71-11dc-b5c6-0019bbdf5d02.jpg (63.3 KB, 890 views)
Old 21st October 2009, 09:52 PM   #4
That looks smart - thanks a lot for the info .
Old 22nd October 2009, 12:24 AM   #5
Perhaps a stupid question, but how does one determine the value of the resistor needed to replace the trim pot?
Old 22nd October 2009, 12:35 AM   #6
DougL is offline DougL  United States
Remove the pot and measure it.
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 22nd October 2009, 05:40 AM   #7
You calculate it
Vout = 1.25 * (1 + Rlower/Rupper)
see http://www.national.com/ds/LM/LM317.pdf
Old 22nd October 2009, 07:05 AM   #8
Formerly Thanh1973
My vote goes with the Salas Reg. You won't be disappointed.
The simplistic Salas low voltage shunt regulator
Old 22nd October 2009, 03:58 PM   #9
Probably better, but this one is cheap and a good starting point.
Old 22nd October 2009, 04:41 PM   #10
sandbasser's Avatar
Has anybody tried a Tread (from Tangent)??? It may be a bit overkill.
- Ray
UcD400 aux supply options PWatts Class D 6 7th July 2011 05:39 PM
UCD Supply ST Transformer Options Juke425 Class D 0 28th July 2008 11:14 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 01:30 AM
Amp6 Power Supply Options Davet Class D 5 20th May 2006 12:37 PM
Gainclone power supply options/questions trespasser_guy Chip Amps 3 28th April 2003 03:52 AM
Page generated in 0.09832 seconds (79.64% PHP - 20.36% MySQL) with 11 queries
