Old 20th February 2010, 05:12 PM   #461
J2 is 30 WPC into 8 ohm and 15 WPC into 4ohm.
This suggest that the bias current is about 1.4A.
Maximum output voltage needs to be at least 21.9v, so rail voltage should be higher, maybe around 23-24 volt considering the 18V transformer.
Old 20th February 2010, 07:28 PM   #462
Send a message via AIM to spiritm2r Send a message via MSN to spiritm2r Send a message via Yahoo to spiritm2r
hi guys,
need opinion,
recently i used Class A 1! mosfet solid state mono block 5watt build from www.audioprjects.com /Mark housten created. it was modified from zen class A Nelson Pass. the sound is so sweet, but difficuilt to drive my 2 way dayton bookshelf.
My qoustion is:
is there better modified to push-pull, or put another N-mosfet like zenNnelson pass ?
my travo(5A) secondary: 12 volt, third : 6 volt. can i medified s2'nd & 3'rd to make hybrid to drive 2c51 tube for being buffer ? what kind a schema should i build ?
welcome any suggestion !
thank's anyway !
Old 20th February 2010, 08:02 PM   #463
maxlorenz's Avatar
Hi spiritm2r,
ZCA from Mark Houston is very good with fullrange (high sensitivity) speakers. I use them with my Audio Nirvana super10 in downsized Autograph replica, without any correcting circuit, and the sound is delicious, with ample, tuneful bas . You should try it with FRs, or try Pass' "DeLite" amp.
Good luck,
M.
"Thou shall build big horn speakers"
Old 20th February 2010, 10:25 PM   #464
flg is offline flg  United States
flg's Avatar
Not forgetting about the Source resistor question but, does this post raise some questions? Answer some???
Aleph Current Source Mod
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 20th February 2010, 11:59 PM   #465
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
just another way to skin a cat .......
I'm not saying that any other is better - but - you must count that that way you have max 2V window for Uce of small bjt .
is it enough - try ;
for moderate and medium levels certainly is , but trouble is around extremes .
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 21st February 2010, 03:00 AM   #466
bobodioulasso's Avatar
Breaking my new toy!
Have you tried it Zen Mod?
Old 21st February 2010, 04:59 AM   #467
flg's Avatar
O.K. this what I got so far...
Old 21st February 2010, 08:59 AM   #468
I do not understand why.
Or do you mean when using power Jfets only?
My intention is to mod an Aleph J, using regular Fets.
Old 22nd February 2010, 11:33 AM   #469
flg's Avatar
Yes, in an Aleph CS, the "govonor" transistor would have much less Vce due to the lower Vth of the Sic devices. The operation of this area of the circuit will degrade because of this. In a J2 however...
Old 22nd February 2010, 12:32 PM   #470
Looking at the simplified schematic of the J2 I wondered if the LU1014D might be used to build a 5W version. I stole the schematic from Nelson and wrote in some values. Note I added a big 4ohm source resistor for the bottom LU1014 it was either that or run the front end at a higher voltage. Even at this 5W level keeping that tiny LU1014 will take some work! Keep in mind this is still just a simplified schematic.
An another way to Firstwatt F1? Idefixes Pass Labs 5 1st February 2012 08:40 PM
Subwoofer and Firstwatt F1 tgrauss Subwoofers 10 3rd June 2009 04:29 PM
Fostex and Firstwatt in car? Ipanema Car Audio 2 11th February 2008 05:32 AM
FirstWatt.com Rory Christ Pass Labs 121 31st May 2004 07:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
