#101 |
Master Burner
Count me in for couple.
#102 |
Formerly Thanh1973
I am interested for a stereo set
#103 |
I'm also interested for a stereo set.
Thx in advance & cheers! |
#104 |
Count me in for a stereo configuration too.
Thanks |
#105 |
HI !
Count me in for stereo set |
#106 |
Hello to all,
for me a stereo set please. Regards Sam
#107 |
not politcally affiliated
Should I do a public google spreadsheet? I am not sure if the Wiki stuff is there, or any better than it used to be.
SemiSouth R085/R100A JFET available now DCB1/BiB #3 on order : SSHV2 Sign up Sheet/Payup Sheet Ends 2-26-2012 CLICK HERE |
#108 |
Great with some action on the thread - inspired me to clean up the layout.
I think the frontend is about ready to be ordered? Any last comments? The board can be used for both BA1 and BA2 - only difference is if C204 is populated or not.
I have started a blogged guide to my F5 boards read it here: F5 pcb v2 blog |
#109 |
Passive Aggressive
Probably not something you would change at this point, but I really like to use the oval pads wherever possible in conjunction with plate through hole. It makes a stronger pad so it doesnt lift and it is easier to solder. With the tiny pads like around the trimmer and small film cap the surface tension of the solder likes to stay on the iron rather than wick down to the tiny pad. Given, around the trimmer the ovals would be hard to use.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#110 |
Here are the boards for bias and output stage.
| Burning Amplifier BA-2 | Nelson Pass | diyAudio.com Articles | 5 | 14th September 2011 07:11 PM |
| The Burning Amp Festival-Burning Gadgets Preview | Zen Mod | Everything Else | 115 | 27th October 2007 06:50 PM |
| Page generated in 0.11732 seconds (76.89% PHP - 23.11% MySQL) with 11 queries |
