#302 | |
#303 | |
If you have a lot to do you can adapt a toaster oven -- there's a specific protocol of heating and cooling that you're "supposed to follow". The RatShack protoboards have enough space between the traces to use "0805" components. For me, this allows a lot more components on a board. Lastly, the gates of the paralleled BF862s will fit on the long runners, but not all smt transistors are configured the same. |
#304 | |
how many times gain actually for 9db? Sorry if my question to basic |
#305 |
Per channel :
Q1 and Q2 will draw Id near to Idss (at max. swing) from pos. rail Q1 is alone on the neg. rail and it will draw a bit less (source doesn't swing as hard as drain) but let us allow for Idss too. For stereo multiply that by 2 and allow enough margin for loses in PSU (shunt reg eats a lot of current). Then multiply everything by 2 to be in comfortable zone.. Page 4 : http://www.live-audio.com/studyhall/dB_calculations.pdf Last edited by juma; 22nd August 2011 at 10:55 AM. |
#306 |
I finally got around to hacking a BF862 adapter together for my jfet sorting jig, using a 6-pin SOT-23 clamshell-type ZIF socket available reasonably cheaply on E-Pay. I had to do some rewiring, but I now have a jig that plugs into the "J170" socket on my tester, so I won't go insane trying to sort parts. I've had a strip of 100 parts waitng around for this development. I wont be doing this preamp, but instead have an RIAA amp that will use gain blocks consisting of a BF862 and a p-channel small signal mosfet. I'll be starting another thread for that project whaen I'm more sure of results.
Anyway, if you search on E-Pay for "SOT-23", you'll run across a lot of parts, and several Chinese/HK sellers offering the socket. It's originally intended as an adapter for some PIC-type device in a 6-pin SOT-23 package, but it will accomodate a 3-pin SOT-23 just fine. |
#307 |
That looks like the one from emcs2009 for $50 - SOT23-6 to DIP 8 PIC -
looks like the clamp presses the transistor down into a recess with the 6 (?) contacts underneath, yes? and connect the pins to external cctry for testing as per your photos. Are there some extra transistor on the pcb? If I may ask, what do you use them for?
... jh |
#308 |
There's nothing extra on the PC board, though there are a few spots here and there for surface mount components. I added a 1k 805 resitor on the board (not visible) as a gate stopper, as the BF862 is very slippery. I've had problems with spurious readings in test jigs before due to oscillation with far less slippery devices - all my new test/sorting jig designs incorporate gate stoppers.
#309 |
Just for clarification, a fair number of the wires you see labelled in the top pic are the gold-plated contacts coming from the socket - I labelled the ones I wanted to use and traced out where the PC board connections went with a VOM (I'm old, but I ain't stupid...). The red-based right angle header was added by me, and that's the bit that plugs into my jig. I cut traces and added jumpers to connect the chosen contacts in the socket to that header. I also removed a second PC board that was sandwiched on top of the one you see in the pictures using a hot-air pencil (a great tool for removing parts in plated-through holes where a fair number of pins are involved - the dragon's breath does it...). The header went into some of the holes left behind by that removal.
#310 |
I bought my socket at Farnell. Not so cheap.
Removed 3 out of the 6 pins. Patrick |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
