Old 6th March 2009, 02:53 PM   #151
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Default Showcase!
Originally posted by mosfets
From the wear and tear on the solder pads of your printed circuit boards, will you continue to deploy them or is it time to place new PCB's in the "twin Towers"?
For now I will use them as is. The damage to the pads is not so terrible if you don't need to re-work them anymore. If ever I think these beasts need an upgrade, I will consider a new front-end PCB (with LS disconnection relay implemented).
Today was a sunny day, which wasn't forecast, but I took the opportunity to take a photoshoot on the amps
first pic:
More Power Igor! More Power!
Old 6th March 2009, 02:54 PM   #152
Bakmeel's Avatar
number 2 out of 6:
Old 6th March 2009, 02:55 PM   #153
Bakmeel's Avatar
number 3:
Old 6th March 2009, 02:57 PM   #154
Bakmeel's Avatar
number 4:
It proudly wears the sign "Pass DIY"
Old 6th March 2009, 02:58 PM   #155
Bakmeel's Avatar
number 5:
Old 6th March 2009, 03:00 PM   #156
Bakmeel's Avatar
number 6:
It's beamer metallic paint yeah...
For Dutch fellow DIY-ers with similar wishes, here's the paintshop that did the work: Spuiterij van Gemert (Dordrecht)
Old 6th March 2009, 03:01 PM   #157
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
what can I say ......
if you're just half good man as your amps are nice and neat ...... then - it was real pleasure messing in this thread
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 6th March 2009, 03:03 PM   #158
Bakmeel's Avatar
The pleasure was fully mutual.... Thanks for all the help and great responses... Off to the next project (whatever that will be)
Old 7th March 2009, 01:49 PM   #159
bees is offline bees  Netherlands
a turntable PSU... ;-)
converting 230V +-50Hz to 230V 50Hz and or 67,5hz
Old 4th February 2013, 07:21 PM   #160
kop89 is offline kop89  United States
Default Aleph 2 not hot enough?
I have just finished one monoblock of my Aleph 2. It makes good sound, but I am wondering whether there is something wrong with my build. I was expecting the heatsink to be scorching hot, but turning the amp on for more than 1 hour and measuring the temperature at one of the MOSFETs mounting bolt, it settles at only 56.7 degree C (around 20C ambient). The heatsinks are only warm and I can put my hands on the heatsinks forever.
My heatsink is the 10.080" profile from HeatsinkUSA:
10.080" - HeatsinkUSA, LLC Store
I am using 4 pieces of 9 inch long section per monoblock (3 MOSFET mounted on each 9 inch piece). It is guesstimated at 0.80 C/W/3 inch. So theoretically my setup is around 0.80/(4x3 inches) = 0.067 C/W.
More info on the build:
1kVA trafo
16 x 15000 uF electrolytics (2.7 mH inductor)
Power supply output at 50V
IRFP244 matched within 10mV
Parts BOM per kk-pcb (Pass Labs ALEPH-2 DIY amplifier PCB)
Maybe I should not worry about all these and just enjoy it.
final aleph 3 sound test jeapel Pass Labs 4 16th May 2006 01:22 PM
Final Decision: which speaker to build? Figo Multi-Way 0 7th December 2003 11:59 PM
Aleph ... which one to build ? thylantyr Pass Labs 6 22nd August 2002 02:24 AM
Copyright ©1999-2013 diyAudio
