So I was sitting in the pub (with my back to the wall), and this guy
came up and said "Oh Mr. Pass, I don't like your volume control - when
I turn the knob it makes a sound like a zipper."
"Sonny," I said, "When I was young, that was exactly the sound we
were looking for."
I bought a 23-step attenuator with SMD resistors off ebay and the listing headline from vendor in Taiwan mentioned Pass 1.7 type. In my ignorance [read as bliss] I had no idea that the zipper was part of the mechanical concept.
I find there is too much physical resistance to this particular zipper.
I have it disassembled at the moment and it would appear that if I remove the front shaft clip I can further disassemble the mechanical mechanism part of it and I wonder if I can change the spring to one with less tension to improve the feel. Ya...that's the ticket!
...what I want for 25 bucks?
"...are ya hungry for me mon? ....zip"
Banned
Joined 2002
Banned
Joined 2002
U talking about this one ?
DACT Type 21 Stepped Attenuator 20K FOR PASS B1 DIY - eBay (item 120502791204 end time Jan-05-10 09:17:39 PST)
No, I bought this one. The heading of the auction I bought mentioned Pass1.7 but I see now they no longer do. Whether this one I've linked to has the clicking step action I don't know.
VALAB 23 Step Attenuator Potentiometer 20K Stereo Log on eBay.ca (item 290376481970 end time 31-Dec-09 15:24:21 EST)
Banned
Joined 2002
boyz - you are nutz ?
what you intend with these technical issues in this thread ?
nobody sane will even stick his nose here ..........
lol, but you just did
nope - I'm hopeless
nobody take me serious , and I'm first on that list .......
Banned
Joined 2002
nope - I'm hopeless
we all do, you = smrt ( bart simpson )
...... if I can change the spring to one with less tension to improve the feel. .....
you need to deform spring with pliers to make it less forceful
then put some grease in mech , and Voilla
I hope the choice i make for my alps pot is going to be good for the b1 pre-amp.
matter of personal taste , in fact - but - if you are searching for soul of the Music , you have two most prominent choices ;
both are completely valid , just different ... and both are superior to any common type pot .
one is ( nota benne - not first) Lightspeed type of attenuator
other one ( nota benne- not second) is transformer based attenuator ( sub types are autotransformer (AVC) or transformer (TVC) ; first is one coil with taps , second one is primary+secondary with taps) .
in both cases buffers on output are must in 90% of cases , except when cables to amp are 100% benign as load and amp is of highish input impedance , presuming that you don't have any active gain stage between attenuator and power amp .
off course - these attenuators are beneficiary as substitution for any attenuator , be it stand-alone or implemented in any active gadget .
I have TKD 4 deck pot (kwayzee 250++ Euro jobie , geschenk from my man Manu) , as part of my selector/volume box , but that Drek is inferior to AVC/TVC or bufferless PSM LS .
naturally - YMM&MV
Yo. Carpenter and Wirewigglers amps are shown in the BAF09 coverage in audioExpress.
You guys are now famous.
15 minutes of fame? Where's that article?
Ya. Tanks! A little spring in our step... zippers and lube..and pie...make life good.
... pie for all!
Banned
Joined 2002
naturally - YMM&MV
I thought about the Lightspeed Kit for the pre-amp volume pot,, but i thought it would be Pricey$$$ to get one going.
I really REALLY liked the sound of the Alps black beauty when we ran it in passive mode with 2 aleph mini amp's and a nice cd player, it was simple clean and just amazing, that is what hooked me on the passive pot im running now.
Jase
- The Pass Pub: The High-End Off Topic Thread
