Re: Re: Re: Where was a mistake ?
Now what's wrong with that?
Magura
Zen Mod said:
- Nail Melter .....
Magura
Zen Mod said:
received ;
can I take some time to think ..... ?
too much work lately ;(
squeek squeek
LU matching
I figure this is a good a place to ask as any, I've looked for a good post but have yet to find it.
I was playing with some matching the vgs of the LU's.
There is mention of not leaving these in too long, connected.
Of course it heats up quickly. It also climbs in voltage as well.
So do I take the first reading? My start @ .865-.950v.
Warmed up to 30 seconds, they are 1.05v to 1.10v. Which is the best number? My room temperature is a bit low when testing, about 60 degrees 15.5C?
Nelson Pass said:I make sure that the devices are at room temperature and I count
1,2,3 just enough time for voltmeter to settle.
The important thing is that all the devices are tested the same way.
Also, I do not regard devices tested on different occasions as matched.
Unless I have to.
Re: big boyz ready for .....
It's got a handle for lifting. If that handle is actually required, then I guess you're on the right track
Magura
Zen Mod said:test ;
Magura - San - big enough ?
Magura
Re: Re: big boyz ready for .....
1KW EI core , good for 2KW 1:2 ( or 2:1) autoformer duty ;
exactly as you said .......
Magura
Babowana said:Choky Susy? Real Susy?
Try this . . .
Don't ask me why . . .
you made me for a moment ..........
but - no .......
look at source resistors as integral parts of LUs , needed to make them behave as Holly Triode
Re: Re: Re: big boyz ready for .....
That's not too far off. They should bring your roll-off down in the mid twenties.
Magura
Magura
Re: Re: Re: Re: big boyz ready for .....
naah...........
btw I forgot this sketch ..... convenient way for PSU
Magura
naah...........
Re: hehe
Naah, converted directly to ISO machine code....
Magura
Zen Mod said:officially - Magura knows how to convert brd to proper dxf file ....
Magura
Re: Re: hehe
Magura
seems that Metaldanske finished his amps , just in time for Danske BAF
entire saga : Donut a' la overkill - DIY Audio Forum
D Day : Donut a' la overkill - DIY Audio Forum - Page 18
be warned : 350++ posts of insane off topic , all relating to making pair of most insane monoblock amps I ever saw .
I'm sorta proud to be a part of this act of passion .
- Choky Susy F3 for LU1014's
