Old 20th September 2008, 11:20 AM   #51
stein2 is offline stein2  Serbia
stein2's Avatar
Originally posted by Zen Mod
J310 will work there ...... as a charm
for both Juma & stein - easy and cheap in Su - Elementa
under 10E/100pcs
So, what you say is this Click the image to open in full size. would suit F5 as preamp but instead of 2SK170, have to use J310?
Old 20th September 2008, 01:38 PM   #52
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by juma
I never tried them, but looking at datasheet for Vishay J310 I see Vgs(off)= -2 to -5 V and gm=8mS, so it looks more like BF245 than K170, right ?
But if you had good experience with J310, it's surely worth a try
170V on steroids , in fact
min 8mS,max 20mS
it's good enough for
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 20th December 2008, 01:36 PM   #53
juma is offline juma  Serbia
juma's Avatar
After few months of experimenting here is the circuit that sounds best to me - it's the same topology as the first one in this thread but with BJTs in output and higher Id through JFETs (6ma).
It takes the +/- 24V from F5 (they are both in the same case - F5 as integrated amp) and preamp's OUT is connected directly to F5's input.
I used the PCB from the post #3 of this thread but with some diferent components and values.
Old 20th December 2008, 01:38 PM   #54
juma's Avatar
This is the preamp:
Old 20th December 2008, 02:08 PM   #55
estman is offline estman  Estonia
Juma,
excellent work. How about MosFet output transistors instead of BJT with lower Source resistors ?
Old 20th December 2008, 02:16 PM   #56
juma's Avatar
Thanks, estman.
Yes, the MOSFETs could be an option if higher output current is wanted. For driving F5, this preamp sounds better with BJTs. I tried IRF610 and IRF9610 - some smaller MOSFETs, like ZVP3306 and ZVN3306 might sound different but they are unobtainable to me.
Old 20th December 2008, 03:11 PM   #57
Hi juma,
no...no, I thought to use only AUDIO mosfets - Toshiba 2sj313/2sk3013 for higher output current and for lower current (F5) Hitachi 2sj76/2sk213.
I have too many 2sj313Y - can send to you for Christmas if you PM me with your data.
Unfortunately I have no adverse part - you must have possibility to get it yourself !
Old 20th December 2008, 03:55 PM   #58
juma's Avatar
Those are also unobtanium
Old 20th December 2008, 06:07 PM   #59
juma's Avatar
estman, YGM
Old 21st December 2008, 03:53 AM   #60
apassgear's Avatar
Hi Juma,
Why should you need an input cap?
Wouldn't a bit of load at the input be enough?
Discrete Op Amp Ideas for a Preamp analog_guy Solid State 16 16th June 2007 04:18 AM
Preamp signal wiring ideas ? gurevise Tubes / Valves 7 30th January 2007 07:19 PM
Ideas for preamp box design paulspencer Analog Line Level 5 26th August 2006 06:46 PM
Ideas for using one ECL82 in a preamp Tyimo Tubes / Valves 17 6th May 2006 05:35 AM
Copyright ©1999-2013 diyAudio
