F5 power amplifier - Page 797 - diyAudio
Old 29th May 2010, 07:30 AM   #7961
meanman1964's Avatar
How critical are the values of the 220F caps can I use 470F?
Old 29th May 2010, 08:07 AM   #7962
juma is offline juma  Germany
juma's Avatar
22k and 220u have RC time constant of a bit less than 5 seconds - with 470u you'll have a bit more than 10 seconds.
The RC time value defines time needed to charge the cap to approximately 63% of the nominal voltage (kind of a slow start). Also, since this is capacitance multiplier, the cap value defines the resulting capacitance i.e. the ripple voltage in output DC voltage.
For example, with 10k and 220u (IRFP240, 4700uF on output, current draw = 1.2A) I get the following results:
- input DC voltage = 24V
- input ripple = 200mV peak
- output DC voltage = 20.2V
- output ripple = 1mV peak
Old 29th May 2010, 06:14 PM   #7963
The one and only
Nelson Pass's Avatar
It's probably easier to cascode the Jfets with some bipolar
transistors.
Old 29th May 2010, 11:58 PM   #7964
transistors.
How?
Old 30th May 2010, 01:36 AM   #7965
The one and only
Add the numbered components. Just about any bipolar devices
will do.
Old 30th May 2010, 08:17 AM   #7966
bobodioulasso's Avatar
Larger heatsinks too.
Old 30th May 2010, 11:46 AM   #7967
Thanks guys but I tried another solution.I've add 8 turn on my toroid and it's now a trannie of 2x18Vac
Old 30th May 2010, 11:59 AM   #7968
jam is offline jam  United States
jam's Avatar
Mr.Pass,
Cascoding the jfet should reduce their non-linear capacitance would this lower the distortion and increase bandwidth to any significant amount to be beneficial if you were using lower voltage rails?
Jam
Old 30th May 2010, 04:54 PM   #7969
The one and only
Yes, but I don't expect it to be a significant improvement. Most
of the capacitance issues are on the output stage.
Old 1st June 2010, 01:23 AM   #7970
jam's Avatar
Thanks Mr. Pass.
I have tried it and cannot hear a change. I guess leave it out if you don't need it. In keeping with Zen tradition......
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
