Old 9th February 2010, 05:45 PM   #7001
labjr is offline labjr  United States
I think you would need a high quality transformer like Jensen. However, I don't imagine your laptop will output good quality sound. I would try an external DAC instead.
Old 9th February 2010, 07:08 PM   #7002
Nelson has a very nice and simple circuit for controlling a fan. It uses a most and the idea is that the fan gets a shot of current to get it running but then runs at ow rpm afterwards. I think the issue was that while you get the fans running slow enough to be quiet,they won't start .
I'll see if I can find it.....
Fran
Old 9th February 2010, 07:38 PM   #7003
umut1001's Avatar
My laptop sounds nice to me.It sounds not as quality as but warmer than my emu1212m card.I will try jensen.What should input and output impedance be ?
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components
Old 9th February 2010, 08:01 PM   #7004
jackinnj's Avatar
Originally Posted by bear View Post
Fans are problematic. At least have the fan operation controlled by a thermistor for speed control or worst case a thermal switch or two with either resistor or control of the set pin of a 3 pin vreg so that it is quiet until it gets hot...
You're not kidding -- fans used to be a primary cause of power supply failure for telcos -- at least according to the guys who sold heat sinks!
The fan on our built in fridge just got replaced -- of course prior to this the micro-controller board was fried by a power transient, this caused the alternator board to fail as the thermal protection didn't kick in (yes, Kitchen-Aid uses a 3-phase fan, and they derive this with an SMPS) -- the failures all relate to the fan bushing which suffers premature wear. They also run these high efficiency appliance compressor fans "hot" which means shortening MTBF.
Go figure -- I run an Audio Research D-115, with a bunch of 6550's most of the time to keep the living room warm, and 4 F5's here in the lab to keep it warm and good-sounding.
Old 9th February 2010, 08:16 PM   #7005
heres that circuit - I used it to run 2 x 3" fans on the case of my mini-aleph (which I had biased the hell out of!).
It works.... but I've missed all this part about using what looks like cpu heatsinks. I would imagine for the few dollars you'd save, you'd be better served by a big chunk o' heatsink......
Fran
Old 9th February 2010, 08:53 PM   #7006
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Fran
what controls the fan on/off via temps ....
Old 9th February 2010, 09:07 PM   #7007
No, the fan runs continuously..... but you can adjust it to low enough speeds with this circuit and it will always start. Given that the F5 produces a fairly constant amount of heat, you are going to need it running all the time anyway with undersized/forced air heatsinks.
Fran
Old 9th February 2010, 10:55 PM   #7008
tinitus is offline tinitus  Europe
umut1001
There have been a member having trouble with connecting F5 to CD player having trafo output
Dont know if it was due to induction or whatever
I dont think i was ever stated whether it was due to the line trafo
But he did have another CD with ordinary output, and had no problem with that one
Old 9th February 2010, 10:57 PM   #7009
cviller is offline cviller  Denmark
cviller's Avatar
The F5 has very high input impedance - could be the reason.
I have started a blogged guide to my F5 boards read it here: F5 pcb v2 blog
Old 9th February 2010, 11:14 PM   #7010
umut1001's Avatar
yeah maybe.Should measure input and output impedances of trafo
Currently Active Users Viewing This Thread: 5 (4 members and 1 guests)
nattonrice, rothay, hofer
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.19799 seconds (63.42% PHP - 36.58% MySQL) with 11 queries
