| Thread Tools | Search this Thread |
#5701 | |
The x-schematic I suppose, is from euvel, he wrote many pages before how to manage it. Open Word, import this wmf (windows meta file) like a picture by insert -picture- from datei. Now you can enlarge the view in Windows and all details are visible! |
#5702 |
Thank Thanh
You are always very helpful , greatly appreciated ! The reason I would like to use 3 pair mosfet everything I have at hand . Heat sink , transformer , mosfets etc . Just need the resistors of course I have redesign my PC boards for the X . Because I want it with out cascode. Also the 2SK1529 & 2SJ200 (I have it) it has less power than the bigger brother 2SK1530 & 2SJ201 used by Smyslow . My AlephX is based on the Kristijan design also I ordered the PC board from him about 4 years a go . It running close to 7A /channel .Total 8 IRFP240/channel . About the sound in one word incredible . I would like to build something similar or at least over 50W in Class A using the F5X topology . Even if it would be 50W the heat sink and the transformer it would be over sized wich is not a problem . If you or someone can help further with the schematic that would be great . That is not my strength . Thank you very much Greets |
#5703 |
Generg
I did tried to enlarge the schematic I attached (without the current lim.) I get a mess only . In one word I can't read it . But because I would like to run my F5X 24V rail probably those resistors used by Smyslow may be it need some adjustment in to the correct value to feet a higher power verizon. Greets |
#5704 | |
#5705 |
Formerly Thanh1973
Hopefully you can read this one
#5706 |
Jeno,
if EUVL's FX5 has 16V rails, 0.22 Ohm drain resistors and 2SJ200/2SK1529 requires about 2V to open up, how many watts can one expect from a balanced act like that ?
Looks like Sponge Bob has killed another thread. |
#5707 |
Thank Thanh
Yes I can read that but I would like to go with these simplified verizon used by smyslow ,only using 3 pair mosfet instead one pair due to the higher power supp . Do I have to change any resistor value since I plane to use 24V rail power supp? For me these is a very important to be clear before I start to go on design PC board or purchase any resistors . Greets |
#5708 |
Why not simply to x the normal F5 with doubled outputs?
#5709 |
Jacco thank you
I need help even to understand your question .Please forgive me I'm not a technician or a engineer . If I have a ready schematic I can go on design the PC board and build it . My question to U it is possible to go on with 3par mosfet with 24V rail idea of course with the necessary mods if it need any . Greets |
#5710 |
Jeno,
a balanced F5 is not the equivalent of a balanced single ended Aleph amplifier. If 50W is all you want, just raise the rails a few points and drop the bias to 1.75 Amp. Patrick picked 16Vdc rails because that's 12Vac rectified.
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| extrip, arche13, brainf, c_door |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.20853 seconds (70.72% PHP - 29.28% MySQL) with 11 queries |
