| Thread Tools | Search this Thread |
#5491 |
The one and only
That is a possibility. To check, you need to measure
the transconductance as a function of frequency. I did write an article on how to do that, as I recall.
#5492 |
After having thought that laterals, like renesas wouldnt work, I thought I better read a bit, which put a small smile on
Regarding bias pots Would someone please tell how to orient them Original F5 schmatic shows the two bias pots mounted opposite each other Others dont, but mount both the same way
#5493 |
The one and only
I don't believe it matters.
#5494 | |
As the discussion concerning LTSpice shows, theoretical and actual experiences can differ. Many here have commented that the commercial F5 using 25V rated caps seem to be pushing it. I would guess more people than just Peter Daniel have 1/4 watt in the R1&R2 positions without any reports of failure that I can recall seeing anywhere on this or the F5 group buy threads. Is this 1.11W max peak reached in class A mode or when pushing into class AB? Since its a peak and unlikely sustained, perhaps the resistors can manage it for a short period. In any case, if its just a failed resistor, I'm ok with taking my chances (an expensive speaker driver would be a different story ). Many here already build the amp without circuit protection or push the bias way past standard F5 spec. DIY's tend to be creatures who like to take some risks to push the performance envelope
#5495 |
Perhaps it's the picture, but those traces look silver. How did you manage that? Garrett |
#5496 |
the traces are tinned probably
#5497 | |
No, they can't. Interpretations do.
If you don't turn the volume knob past 8 o'clock you can use 1/16W resistors. |
#5498 |
#5499 |
I like the sound of the F5 without current limiter more, may be because my Thiel SCS 4 has only 4 Ohm.
But my current is going up and up, slowly but sure. Will be there a stop? Or is it impossible to get a balance? Oh I forgot I put away the thermistors too! |
#5500 | |
I would like to build my F-5 similar to this example. Russellc |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| unixdeveloper, Oreda, rothay, hofer |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 06:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
| Page generated in 0.17321 seconds (58.32% PHP - 41.68% MySQL) with 11 queries |
