Old 19th October 2009, 05:23 PM   #5231
fff0 is offline fff0  Singapore
Hi Zen/ Magura,
Thanks for the input.
Can I know if I can feed F5 with +48v and 0v (gnd), will it work? no?
Old 19th October 2009, 05:50 PM   #5232
bobodioulasso's Avatar
see post 4239
Old 19th October 2009, 06:29 PM   #5233
cviller is offline cviller  Denmark
cviller's Avatar
Originally Posted by umut1001 View Post
hi huseyin how are you..i wish you will draw a good pcb for us and we will group buy...
There are already 3 designs available, so unless you want to do it for the experience, I doubt there will be much action in such a gb.
Cviller: Gb: F5 Pcb
Peter Daniel: F5 pcb group buy...
suds: FirstWatt F3/ F5 Clone GB
I have started a blogged guide to my F5 boards read it here: F5 pcb v2 blog
Old 19th October 2009, 07:50 PM   #5234
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
yeah - with so-called Quad arrangement of PSU
see what bobodioulasso wrote
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 20th October 2009, 11:14 AM   #5235
if I were designing a CLC for an F5, I would use 6m8F//6m8F//6m8F as the first capacitor bank, then 180turns of 1.6mm diameter enameled copper on a 48mm air core former (700gms of copper) and then 15mF//15mF//15mF as the second stage capacitor bank.
Your two channels will require a minimum of 250mF and 3.1kg of copper. That is an expensive PSU. It will work for both the ClassA operation (1.3A bias) and for the ClassAB operation.
It will even work with a ClassAB amplifier (150W into 8r0) irrespective of the output stage bias.
regards Andrew T.
Old 20th October 2009, 11:29 AM   #5236
sekess is offline sekess  United States
Hi AndrewT,
2 questions:
1. Is there a reason why you need so much more capacitance for a CLC as compared with a CRC?
2. In your example: "180turns of 1.6mm diameter enameled copper on a 48mm air core former " -- how many Henries does that come out to?
Thanks,
Steve
Old 20th October 2009, 01:13 PM   #5237
umut1001's Avatar
Default how to calculate the most reliable power supply?
hi Andrew..i dont know how to calculate the most reliable power supply for F5 amp..i have these materials
1-) 0-18 0-18 0-18 0-18 600VA toroidal transformer
2-)8x 25volts 47mf kendeil capacitors
3-)0.47 ohm 3watts dale resistors
would you say how to make the best supply and best noise reduction and how many resistors should i connect paralleled for it?thank you
Old 20th October 2009, 01:31 PM   #5238
+-45mF is not a lot for a ClassA amp that can drive 4ohms into ClassAB.
I posted the air core inductor spreadsheet quite a while ago.
183Turns calculates to 2.0mH and has 0r34 resistance, but it's big. 14.3turns/layer, 12.9layers = 184Turns resulting in 89.2mm diameter and 22.9mm spool width, using 40m of wire.
2mH using 1.9mm wire gives 103mm diameter and uses more than a 1kg spool of wire.
regards Andrew T.
Old 20th October 2009, 02:45 PM   #5239
I just completed my F5. The value of resistor is according to reference on the passdiy web. However, when I adjusted the bias and output DC, I adjusted P1 and P2 to keep voltage of R11 around 0.6V. I noticed the value was changed all the time. It can't be fixed in a value. The output DC is in the same situation. What's wrong?
Old 20th October 2009, 03:02 PM   #5240
Zen Mod's Avatar
you must have input grounded while adjusting bias ands offset
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
rothay, hofer
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Page generated in 0.19599 seconds (65.25% PHP - 34.75% MySQL) with 11 queries
