#2811 |
Peter,
Very clean indeed. Where do you get those speaker terminals? I've noticed that you use them a lot. Thanks for sharing. ![]() Looney |
#2812 |
I get them from Cardas (Patented Binding Posts), both Percy and Partsconnexion sell them too.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2813 | |
Nice pictures of your setup! ![]() The optimal vertical placement of the fets is 1/3 from the bottom, but I guess you already know that. I think you might be pushing it by running two channels on one conrad sink - when you put the whole thing in an enclosing, the sinks will loose some efficiency and even worse if you place the amp in a audio furniture later on. Lowering the bias will give you more distortion. |
#2814 | |
When I tried Aleph 30 couple years ago, I admired the midrange quality but the highs were lacking and I never went back to this amp again. F3 was interesting right from a start, but I found that the output coupling cap was a limiting factor and if I didn't do anything about it, I wouldn't be probably using that amp either. With cap modification, the amp is very smooth, relaxing and detailed. I have it in my main system, with A75 at bottom end, and I couldn't be asking for more. When I listened to F5 first time, I thought pretty good, but probably not good enough to replace GC, another wasted effort ![]() Then I thought why not removing all the parts that are not really needed and off went current limiting circuitry: the amp opened up and instead of boring became much more interesting and involving, to a point that I spent whole evening listening to it. Just to make sure that I'm hearing things right, I put GC back in a system and suddenly I understood what Srajan meant when talking about "leading edges" The outlines of the tones are much better defined with F5, GC is softer here and it almost feels like distortion. The F5 also exceeds in tonal purity: all the sounds have more substance. Comparing to F3, it is more intense amp, which also requires better match of the rest of a system.The amp is so interesting now, that after 2 years rest, I put my TT rig back into use this evening....
#2815 | |
Formerly "jh6you". R.I.P.
I hardly understand how come the sound has been opened up after romoving the current limiting circuitry. The Q5 and Q6 are off, doing nothing, till the amp see the maximum current, say about 10A I know you have a special ears diferrent from the ordinary people, tho . . . ![]() Cheers, >> <<
#2816 |
Well, if you read F5 article you may notice that I might not be the only one giving current limiting a "bad rap".
#2817 |
I know.
"Current limiting gets a bad rap in general, but I think it¡¯s a matter of where and how the limits are set. If you build this amplifier, you are of course welcome to delete this portion of the circuit, and of course you will not complain if a shorted output lets the smoke out of your amplifier. As it is, you will still be taking some chances with a shorted output." And, I have both with and without the current limiting circuit ![]() >> <<
#2818 | |
You forgot to look at the Conrad spec sheet and particularly the de-rating information. When DeltaT is less than the test value used by the manufacturer then the sink MUST be de-rated according to the manufacturer's graph or formula. When the heat source is connected to one small area of the sink instaed of spread across the whole heatsink area the sink must be de-rated for the temperature drop to the extremities. Again manufacturers give some guidance on this. I suspect that two devices on a wide Conrad sink that is rated @ 0.2C/W will rise not 25degC, but more like 35 to 40degC. |
#2819 | |
But they start to turn on @ ~ 400mV. That reduces the trigger point for the current limiting to ~ 2/3 of set current. This lower limit should be just above the maximum current you expect your load to demand. For a 25W into 8ohm speaker expect maximum output voltage ~20Vpk. This can generate up to 7Apk into a reactive 8ohm speaker. Some recent posts have suggested that reactive speakers are more demanding than generally assumed in the past. If this is the case then maximum current could approach 5times what the nominal speaker impedance may lead you to expect. If you have a particularly demanding speaker that demands upto 12Apk from a 25W amplifier and the protection transistors are starting to turn on @ ~ 6A then expect there to be some audible effect. It looks to me that the set point for the current protection should be raised from 10Apk to 18Apk or more to remove this audible effect. |
#2820 |
When the barrier voltage, Vbe, of a TR is 0.6, how come it turns on at 0.4V?
And, the others . . . Papa, listen to Andrew.
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
