#21 | |||
NICE answers ZenMod... Jesper.
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp. |
#22 | ||
Official Court Jester
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
#23 | |
Crazy Yankee. |
#24 | ||
I am not sure in understand, please explain. Quote:
Dinesh |
#25 | |
see cookbook for assembly
#26 |
ZenMod, I know that you can't remember the open loop gain / close loop gain, of the circuit, but is it possible that it can be explained howto calculate it.
The thing ís, that maybe somebody want to increase the gain, which is 100k / 10k = 10x of 'standard' circuit (R1, R3, R5, R6) give's this gain. I increased the 100k(R5, R6) to 147,5k, and decreased the R1, R3 to 6,8k giving me approx. 20x of gain... eg. the swings around 40v with an input of 2v in my case.I can't remember the excact, 'max' voltage which the F4 can handle... But if one look forward to attach, an not so gain-strong phonostage perhaps, giving out.. say 1v, the F4 will only be feeded with 10v on standard , and around 20v in my setup... If the F4 need's... let's say around 25-30v for full throttle, the thing is still missing something to drive it to the max.I know, that all such adjustment's has a backside, but i hope you got my idea, to conclude the stuff in the revissed cooking-book, BUT this is just an idea i have. My DAC, gives around 1,6v out, so i think my setting's on is perfect for that, giving around a voltageswing of 34v (16v on standard )...Jesper.
#27 |
ZM, anybody,
C4/C5 & C11/C12 are the output caps, I know you have said use your fav. But, I do not have a "fav". I am thinking of using Black Gate N 47mfd 50V available in partsconnexion for $10, bypassed with 1mfd Vishay MKP 416-420 available on Digikey for a buck. Why 47mfd? Well, my pumpkin will also be doing double duty of a headphone amp. I thought a larger cap will help with lower impedance cans. Or is this not a good idea? What do you guys think of this choice? Any other suggestions? Thanks, Dinesh |
#28 | |
lykkkkkgreedydanske it's hard to please everyone ; with phono section as that - you can't have all ; I told you before - you can't go near OLG without sacrifices , just beacuse everything is matter of compromises ; near OLG , you loose both freq extremes ( not that both are necessary) what you also loose is amount of X feedback ; anyway - it's up to you to choose what's best for your ears in your boots - I'll toss both and F4 ( as a gift to Magura , just because he doesn't have them ) and make one nice toob system ...........![]() anyway - for test - desolder feedback resistors and measure OLG at 1KHz ; you can measure also OLG at 20Hz and 20KHz , while you are at it . I'm sorta short in time , because it will take few mnths that I make my own ; all I have in this moment is just one populated Shunty pcb.let us know what results are ![]() regarding calcs - I remember that my calcs aren't very near measured ; I'm primary toob guy - used to graphs and rulers ,along with calculator ; there must be something I missed for OLG calculus .... those dreky mnfctrrs of 3-7 legged fuses make so small and useless graphs
#29 | |
Dinesh ; you package ( + ) , along with others is packed and ready to sending ;I just kissed closed doors of post office today ; seems to me that you found your fave caps ![]() just go for it . somewhere - in one of my useless OT threads - I mention that I tried with cans - with stock (4uF) output caps , cans's impedance was ...... both channels in parallel - so must be no more than 50 ohms........ to cut a ... sound was pretty decent , no flabbyness ....... blabla think about decreasing output resistors to ~ 22E , from 47 as they are now ; if needed - we can later try something simple - increasing Iq in output stage(s) don't forget to take cans off the head , if BG's need little burning in
#30 | ||||
Thanks a lot. Quote:
| Page generated in 0.15370 seconds (86.00% PHP - 14.00% MySQL) with 11 queries |
