Jfet BOZ - Page 104 - diyAudio
Old 16th May 2011, 05:26 PM   #1031
ramallo is offline ramallo  Europe
ramallo's Avatar
Send a message via Skype™ to ramallo
After several turns around the boz (Raising the voltage, feedback loop, more value to the source resistor, less value the supply resistor .....), I left the boz like is. I found that is very critic to the supply alimentation, for my 8mA IDSS 2SK170BL the best value for the lowest distortion is 15,55V, I changed the zener to a TL431 with pot (For a fine tuning).
The schematic
Happiness is a warm soldering iron
Old 16th May 2011, 09:57 PM   #1032
mhouston's Avatar
Nice build.
Old 16th May 2011, 11:08 PM   #1033
ramallo's Avatar
Originally Posted by mhouston View Post
Nice build.
Thanks!
Old 17th May 2011, 02:13 AM   #1034
anilva is offline anilva  India
The schematic
I am using a similar board. If I understood your post, you removed the 25k trimmer pot at the input and replaced with a step attentuator of similar value as volume control isn't it? You also seem to have 3 input with selector switch. Any passive network used there?
Thanks.
DIY F5, F5T, F6, Aleph J, Fostex 206 based BLH, Altec Onken with 515 LF & 288 HF, Technics SP10 MKII & EMT950 turntables
Old 17th May 2011, 08:49 AM   #1035
Manu is offline Manu  Europe
Manu's Avatar
Very nice
Manu
.. I left the boz like is ...
Manu, masked agent of entropy & ZMs Čiko
Old 17th May 2011, 09:57 AM   #1036
ramallo's Avatar
Thanks.
Yes, I didn't used the board potentiometers and I added a 20K step attenuator. The selector are a 2 Way 6 positions, but I use just two. Also I changed the zener by a TL431 on a small board.
I use all wires with screen for get the best crosstalk, but the earth of the inputs is conected to the output conector and these to the board.
This is the input:
Click the image to open in full size.is
And this is the 431 board:
431 layout
431
Old 17th May 2011, 11:13 AM   #1037
Thanks. I am in the process of putting this into a box.
Old 17th May 2011, 12:07 PM   #1038
ramallo's Avatar
Originally Posted by Manu View Post
Very nice
Manu
Thanks Manu,
I had a big surprise when I started to read this thread and I saw that this chinese pcb is a copy of your pcb.
Thanks for your pcb design!
Old 1st July 2011, 07:41 PM   #1039
cjkpkg is offline cjkpkg  United States
OK...I built mine apparently with 2sk370's originally must be thats what I had laying around....
So one channel had been going wonky and I ruled out the coupling caps and everything else but the JFETS...It has a lot of hours on it so I figured lets change out the JFETS and see if that helps...
All I have left now are a handful of 2sk170s so I plopped a pair in. Distortion city!!! These are the BL type but with the source and drain resistors I had in place all I could eek out of them was 6ma.
I dropped the drain resistor to 1K from 2.2K and dropped the source resistor down to 5 ohms(all I had was another pair of 10ohm resistors).
This cranked the 2sk170s up to about 8.5mA and boy is the sound sweet again!!!
I took the old JFETBOZ out and just plugged the ipod into the F4(with integrated BA2 front end) and while it sounded great the gain was just quite not enough....
Now with the JFETBOZ back in action all is right with the world again!
If it weren't for Diyaudio I would never know where to immediately hone in to troubleshoot this awesome little preamp. THANK YOU!
Old 24th August 2011, 03:43 PM   #1040
binhaudio's Avatar
Hello everyone! after the reference and read all 104 pages of the pre JFET Boz, I decided to install this pre discount.
Map that I choose to do is follow the plan of ramallo because my transformers and capacitors suitable voltage. when done, I tried the pre transplant with my computer speakers.
Unexpectedly! JFET with two children but that the sound quality of this pre show or out of my imagination. Bass is deep and warm voice is smooth and rustic MID, also known TRELLE the towering and clear to the exotic.
Before I installed the pre this was my computer speakers are performing normally and faint. but when the pre transplant into the speakers of my computer completely makeover scholarship and I am extremely interested in the pre this.
Please thank Nelson PASS and everyone on the forum was to share knowledge and experience for me.
because my English ability is very bad so I used google translate to translate it a bit confusing. expect people to sympathize.
And here's a picture of my pre Boz JFET
JFet BOZ Tyimo Pass Labs 14 30th April 2006 03:18 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
How to use Jfet? lumanauw Pass Labs 5 7th April 2005 03:12 AM
Copyright 1999-2017 diyAudio
