Hi Chris,
I realize that djk's suggestion is good in a pinch. I was just trying to find a plug and play part for the guy that was looking for an exact replacement. I cannot seem to find a NTE replacement or anything else listed. Yes, you could use either a quad or a dual with some jumpers and provisions made for the extra sections.
Hi Joe,
Try http://pacificsemi.com/search.php (found it by searching NJM4558S) or some more local suppliers. Very common with Japanese service networks, just contact a warranty shop for one of them.
-Chris
Edit: another one but out of stock http://www.mcminone.com/search.asp?keyword=njm4558s&btnSubmit.x=0&btnSubmit.y=0&btnSubmit=GO
I'll pretend I didn't see that.I cannot seem to find a NTE replacement or anything else listed.
-Chris
tough crowd
Kiss my op-amp Joe, I am blind, but not as old as SY.
And where you tie off the positive inputs might depend on the chip. There are some op-amps that actually power-down sections depending on V common mode at the inputs. There are even amps where the output will toggle (reverse) if you mess the inputs 'round enough.
http://www.mcminone.com/search.asp?...AMP&searchin=off&btnSubmit.x=10&btnSubmit.y=8
Sort By:SKUManufacturerManufacturer PartAvailabilityPrice-High to LowPrice-Low to High Found: 4
SKU Description Availability Price Select
UPC4570HA NEC IC 9-PIN SIP DUAL OP AMP BIPOLAR
NEC IC 9-PIN SIP DUAL OP AMP BIPOLAR I.C(MONO-ANA)
Mfr. Name: MCM An InOne Company
In Stock
(72 available) 1+ $0.98
10+ $0.89
25+ $0.77
NJM4556S JRC IC 9-PIN SIP OP-AMP DUAL BIPOLAR *SS
JRC IC 9-PIN SIP OP-AMP DUAL BIPOLAR *SS IC, Number of Pins: 8, Package: SIP
In Stock
(4 available) 1+ $2.86
10+ $2.80
25+ $2.62
NJM4559S DISCD JRC IC 9-PIN SIP DUAL OP AMP BIPOLAR *SS
DISCD JRC IC 9-PIN SIP DUAL OP AMP BIPOLAR *SS IC, Number of Pins: 9, Package: SIP
Out of Stock
(Lead time 0 days) 1+ $1.45
10+ $1.38
25+ $1.29
TA75559S SUB ONLY TOSHIBA IC 9-PIN SIP DUAL OP AMP BIPOLAR
SUB ONLY TOSHIBA IC 9-PIN SIP DUAL OP AMP BIPOLAR IC, Function: Operational Amplifier, P
Out of Stock
(Lead time 28 days) 1+ $3.05
5+ $2.70
10+ $2.40
Home | About MCM | Contact US | Help Center | Site Map | Terms & Conditions
© 2005 MCM, an InOne Company
Contact MCM, an InOne company:
Sales: 1-800-543-4330
Customer Service: 1-877-626-3532
About SSL Certificates
In Stock
10+ $0.89
25+ $0.77
In Stock
10+ $2.80
25+ $2.62
Out of Stock
10+ $1.38
25+ $1.29
Out of Stock
5+ $2.70
10+ $2.40
Hi poobah,
Look in za old broken unit. In dar, you find da gold.
To heck with brokers. They want you to buy a ton, not onesy twosy.
The guys who normally carry Japanese semi's will have them, as will every shop in the warranty network. It's one of the most common parts out there.
-Chris
-Chris
Kiss my op-amp Joe,
What did I do for this?
Old and blind me bad
I am old and blind not you oh great Poobah
You could find some NJM4559 or NJM4560 types for Joe.
You guys are a laugh a minute. Ok, I was having a blond moment and forgot the damn prefex on the part number.
- Design & Build
- Parts
- 4558S inline op amp needed
