Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st February 2003, 04:16 PM   #61
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Here's quote from his site:
>Exclusively for our customers we have measured for & marked the outer foil lead
end of most larger value capacitors with a black dot for optimum orientation.
For most series signal path applications I recommend orienting the outer foil lead
toward the load, as though the signal were exiting the cap at the end with the
dot. For shunt and power supply bypass applications, orient the black dot toward
ground. At the very least, observe the same alignment in the left & right channels.<
And here's a pic of some of the caps from him. You can see that there is only one cap which has a black dot according to flow of the lettering. I'm not sure how he measures that, maybe something about the inductance?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 1st February 2003, 04:25 PM   #62
diyAudio Senior Member
fdegrove's Avatar
Default BLACK DOTS.
Hi Peter,
I'm not sure how he measures that, maybe something about inductance?
Quite probably...and I don't have a measuring bridge for that.
I notice one cap in the pic has already delvelopped fruckles.
Thanks Peter,if I find an easy way to tell which end is which,I'll let you know.
Eh,eh...wait 'till Bob finds out about this...
Frank
Old 1st February 2003, 04:57 PM   #63
Bobken is offline Bobken  United Kingdom
Default Re: Re: Re: LE CHEF.
Originally posted by Peter Daniel
I'm still experimenting with the caps and although the end of the road is nowhere in sight, the best way is to try everything myself.
Bob,
I wonder what are your findings regarding Cerafines. I thought they were next best thing after BG, but recently found some posts, with people having different views regarding those Elna caps. I bought last batch of them from Parts Connections and was hoping to use them in my best amp project.
As to the price of BG, they are not that awfully expensive, it's just dealers markup makes it seem like. We recently purchase 100 of them directly from Japan and the price was about 1/3 of what the local dealer is asking for.
Peter,
Prior to getting hooked on (Non-Polar) BGs, my favourite electrolytics were Cerafines and Oscons, depending on locations and required voltages etc.
I had also tried a few Elna Silmics which were at least as good as, if not rather better, than their Cerafines, but they were not (when I last bought any electrolytics) as readily available in so many different values/voltages etc.
It is always hard to contemplate 'going back', so to speak, when you have experienced something that seems superior, but I always quite liked Cerafines and found that they had no overt 'nasties', and certainly they were very much better IMO than any of the alternatives which were then available.
Before the days of the Internet, and when communication was a pain in the a*s*, I tended to buy 'special' components like these 'direct' in quite large quantities to get a good price on them, and, incidentally, I am thinking about putting some of them up for sale as I will probably never need many that I still have left.
RTXs for example, I bought in 100's, and I have a lot of them in boxes.
Because I did buy a lot of components at one time, I tended to use what I had available (for obvious reasons), but nowadays I am only really interested in the very best components available, and I only build a very few new circuits now.
I still have a few Cerafines in use in odd bits of gear (and some in boxes!) and they are certainly not poor enough to warrant panicking over replacing them, but I feel that where I do still use them, they could now be the weakest link in the chain in my equipment.
In saying this, before BGs, I was not in any way dissatisfied with the Cerafines, it is just that I have now experienced something rather better, but the cost differential is enormous, and for many people, I would strongly suggest that there are better ways to spend an audio budget, than to replace Cerafines with NP BGs.
I am not a Scotch drinker (my Brother makes up for it! ), but I guess it would be like going back to drinking a younger and less enjoyable Malt Whiskey, perhaps, with a slightly less 'refined' taste, but most electrolytics would be akin to cheapo blended stuff!
Every other passive component in my system is now just about the highest quality I know of, sonically, and at present I have not been sufficiently impressed with any new circuit (except some of Nelson's, but I have this mental block over the electrolytics here!), so any audio budget I have will be very likely spent on 'putting the icing on the cake' with my existing gear.
I have always been an 'evolutionary' by nature, rather than a 'revolutionary', and ever since I started to 'roll my own' with audio gear I have tended to improve the existing circuits, wherever possible, instead of continually starting over again.
The very few Cerafines I have left, are one of the equally few areas where there is any realistic possibility of gaining any further improvements, so, if I do replace these, it will be on this basis, rather than through any dissatisfaction with these particular caps.
What I am also attempting to establish is the truth over Jelmax's claims about the advisability of going over to using BGs *exclusively* in a particular circuit, to eliminate the supposed distortions they claim are apparent with all other electrolytic caps.
A while ago I fought a vigorous campaign in the Forum which most people seemingly took be blind and wholehearted support for BGs, but this was never so, and I also suffered from the "don't shoot the messenger" syndrome, merely because I had frequently asked people to read *properly* for themselves, what Jelmax had to say in their white-papers.
In reality, so far I have found that every claim that Jelmax had made, and which I had personally put to the test, seemed to be valid, even though their literature was very poorly worded etc., and they are undeniably superb sounding caps when they have been properly burned-in.
However, as I also said on numerous occasions in the BGs threads, I don't believe all that I read from anyone, until I have actually found out for myself, and this 'synergy' suggestion, is one area where I wonder if there is some 'marketing license' occurring.
Only time will tell about the BGs, and I believe that you will not regret purchasing the Cerafines, especially if you got them at a good price. On a simple value-for-money basis, even at full price, they were a good deal, in my view.
Bob
Old 1st February 2003, 05:20 PM   #64
Default I'm not a greenhorn!
Originally posted by fdegrove
Hi Peter,
Come on Frank, give a guy a little credit when he has been playing about with these kind of things for over 30 years!!!
I was about to respond to your earlier post after just spending an hour answering Peter, when I read your subsequent comment about MIT cap's orientation.
You do need to measure them, as they are *not* consistant exactly as Peter said, and I am your man for the methodology.
I am supposed to be doing something for the SOH for a few minutes, and when this is done, I will post again.
I imagine (being a valve freak, and with all the problems they need to have sorted out!) you do have a 'scope?
Bob
Old 1st February 2003, 06:17 PM   #65
Default Re: Re: Re: Re: LE CHEF.
Hi Bob,
Are you trying to say that you are using only Non-Polar BG in amp's PS?
If we are talking about SS and considering average Aleph amp with at least 60,000uF per channel (although it is on a lower side) the cost of N type BG, even when buying directly from Japan, would be in a range of $2000 USD (which is actually not that bad when I think about it).
I might organise a group purchase order when there is enough interest.
How Non-Polar compare to Standard Polarised which are 3 times cheaper?
www.audiosector.com
Old 1st February 2003, 06:26 PM   #66
Here's a pic from Krell literature and their reference MRA amp. All the caps are Black Gates.
www.audiosector.com
Old 1st February 2003, 06:33 PM   #67
fdegrove's Avatar
Default MIT.
Hi Bob,
Bob,I don't doubt neither Peter nor Michael Percy for a minute.
It's just that I distinctly remember the instructions that came with the caps where they distinctly stressed that the caps had to be hooked up as I described in a post above.
What problems,Bob?
I sold about 2.000.000 valves in ten years time,every single one got tested and I never had more than 1% drop outs.
Much closer tolerances than any semi-conductors I've seen.
Still,to answer your question,yes I can get a scope to measure the caps.
If you don't mind,that is.
Come to think of it,I always selected the MITs for close channel to channel matching and to neutralise any static charge on the plastic surrounding wrap I put a little dot of grapphite charged spray on them with a pencil.
Incidentally about the size of what is shown on Peters' caps.
Naturally that works for any film cap.
Peter,give it a try too.
Frank
Old 1st February 2003, 06:36 PM   #68
fdegrove's Avatar
Default JEEEEZZZZZ.
That must be their answer to the SET brigade?
Just when we discuss in the tube section that paralling tubes is not such a bright idea....
Frank
Old 1st February 2003, 07:40 PM   #69
Hi Frank,
First, the earlier post.
Yes, I too like Ansars, and they are probably better than Solens sonically.
In fact they are the only polyprop cap I will use in speaker X'overs, apart from Hovlands (I don't just now recall for sure, but I think they are also polyprop), but I will only use them for the big jobs, (i.e. 100uFs etc., shunting woofers).
Anything much smaller I like to use RTXs, so you can imagine how much my X'overs cost to make!
Who is Brian cherry, and what are his "Jupiters"?
***Sexing Capacitors***
Before I start on the cap orientation methodology, I will clearly state that these 'instructions' stem entirely from my own experiments, I do not claim in any way that they are the best way of doing the job, I am not a cap orientation expert, but THEY DO WORK-period.
I am only posting them because someone has asked for this information, and I happen to know from my own experiences, how this job can be done.
I have done this (i.e. sexing capacitors) using this methodology many hundreds of times, even though I cannot provide any written proof to support it, and I don't have any outside references to quote.
Therefore, I will not appreciate any smartarse theoretician subsequently telling me why they don't work, nor giving me a load of irrelevant techno-crap reasons to support their contention.
Method.
AC power is supplied to the DUT via a Variac set to approx. 10-15 volts AC output, but if a sine wave generator or similar is available with this level of output, this would be fine too. (Generally use lower voltages for larger caps, to avoid too much loading of the generator and DUT, but very small caps may need higher voltages to give a proper reading)
Regrettably, most audio oscillators I have seen don't give a high enough voltage output.
Readings are obtained by attaching a 'sensing' coil to the probe of an oscilloscope and I have found that a miniature 12 volt relay with a coil of 700 ohms impedance (which I just had to hand) was ideal, but this is in no way critical. I would *guess* that almost any small multiturn coil of wire will indicate some kind of reading when one end (only) is attached to a 'scope probe.
Set scope Probe to X1, Time/Div set at 5mS, and Sensitivity set to 20mV. Again, these settings can be varied, but this is a good starting point to see some readings on an 'average' cap.
The coil should be rested at the side of the DUT, but precise location is unimportant since the two 'opposite' readings should be quite positive. Don't deliberately move the coil position between the two readings, though, as this may distort the results.
At rest (i.e. with no signal applied to the DUT) a clipped sinewave should be seen on the scope, and this waveform is the 'datum'.
Connect the AC generator (using both leads) to the cap, and one of two things will happen to the 'scope trace.
1) The 'scope waveform will increase by a significant factor.
2) The 'scope waveform will stay pretty much the same (possible marginal increase).
If the *difference* between the two waveforms is not very well defined, try to reorientate the cap and/or move the coil about relative to the cap until a very positive difference is seen.
When the waveform is as in 1) above (i.e. larger), the 'live' lead of the generator is attached to the 'outer' cap foil.
In reality, it is a lot easier to do than perhaps the above might suggest, but if those instructions are followed carefully, it will give a satisfactory result. There is nothing critical about the procedure, and having achieved a satisfactory reading once, it will seem like 'riding a bicycle' thereafter, and it merely takes seconds for each cap.
All that is being attempted here is to inject a signal, which is then
picked up by the coil through inductance, to either the outer or inner foil. When the signal is sent to the outer foil, a much larger signal will be picked up by the 'proximity' coil than if the signal is sent to the inner foil, which is partially shielded by the then grounded outer foil.
Lets see what the fans can make out of that, Frank!
Bob
Old 1st February 2003, 07:56 PM   #70
fdegrove's Avatar
Default VIVA BOB.
Hi Bob,
Makes sense to me.
Thank you so much for making the effort.
When I mentioned the Ansar Caps I was thinking of them as used in valved PSUs of course.
I can't help it but I always think of you as a valve man rather than a solid state user...honest,I do.
Didn't Russ Andrews from RATA distribute these at one point in time ?
Maybe he still does anyway...
Thanks again,
Frank
WTB:Black Gate Caps Fast996 Swap Meet 2 11th November 2008 05:45 AM
Black Gate Caps shock ssmith Parts 18 8th June 2007 05:10 AM
Black Gate Caps - end of the road Nuuk Parts 7 6th September 2004 11:41 PM
Asc/Angela vs Black Gate caps hardcore Tubes / Valves 9 24th July 2003 06:38 AM
Page generated in 0.15460 seconds (87.90% PHP - 12.10% MySQL) with 11 queries
