| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Are schottky diodes always preferred to soft/fast recovery or stealth diodes in rectifiers as long as there are available schottky diodes with required maximum repetitive reverse voltage ? Thanks... MB |
#2 |
Schottky diodes:
+ Low forward voltage + Fast recovery time - Not available in ratings higher than about 60V - high leakage current Soft/Fast Recovery diodes: + Fast Recovery Time + High voltage rating + Low leakage current - High foward voltage Choose whichever is going to be more efficent in your circuit. |
#3 |
There is a noise aspect to this as well. Wich makes more noise?? It seems to differ from application to application.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#4 |
Seems that there are manufactureres who have managed to get round the low voltage limitation with Schottky diodes :
www.cree.com I bought some 600V 1A ones from an online retailer a while back but have not tried them out yet. Regards, Joe Ling Malaysia |
#5 |
Are they expensive??
Magura
#6 | |
Well the 'Soft Recovery' diodes were specifically designed to reduce switching noise. They have a gradual turnoff which rounds off the switching current waveform. This results in a lot less RF noise, with a small sacrifice in efficency. However if you are using the diodes in a standard 50Hz bridge rectifier then there will really be no diffrence because the frequency is so low. |
#7 | ||
Banned
#8 |
Oops, meant to write "generally not available over 60V".
#9 | |
#10 |
600V 1A ones cost USD1.60
Regards, Joe Ling |
| Fast recovery diodes help / advice please ? | AndrewGM | Solid State | 17 | 15th April 2009 09:39 PM |
| Fast Recovery rectifier diodes | rtarbell | Power Supplies | 91 | 16th December 2008 06:38 PM |
| Fast soft-recovery controlled avalanche rectifiers? | quantran | Parts | 6 | 5th May 2007 04:16 PM |
| Schottky or ultrafast soft recovery diodes? | novec | Power Supplies | 10 | 21st September 2006 12:57 PM |
| Fairchild Stealth soft recovery fast switching diodes | KevinLee | Swap Meet | 3 | 10th January 2006 09:53 PM |
| Page generated in 0.10565 seconds (82.28% PHP - 17.72% MySQL) with 10 queries |
