Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd June 2012, 03:10 PM   #1
augustoriodosul's Avatar
Default Panasonic 22.000 uF fake caps?
Can anyone help explain what happens to an electrolytic cap "Panasonic" 22,000 uF x 63 volts, thus exploding. It was bought at a bargain store Analog Metric (Panasonic 22000uf 63V AUDIO Electrolytic Capacitor_Panasonic_Capacitor_Analog Metric - DIY Audio Kit)
thank you
Old 22nd June 2012, 03:18 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
They don't look original to me. If the are not used with the wrong polarity you might conclude they are fakes. I would count out that is is an exemplary faulty unit when it is an original Panasonic cap.
I paid less for original Kendeil caps....
It's only audio
Old 22nd June 2012, 05:57 PM   #3
theAnonymous1's Avatar
These only seem to be available from HK sellers. I can't find a similar Panasonic capacitor from any reputable distributor. The closest match I can find is 40mm in diameter, not 35mm.
It makes the situation even more suspicious that the seller you linked to also sells a nearly identical "Hitachi" cap....
Hitachi HCG FA 22000uf 63V Electrolytic Capacitor_others_Capacitor_Analog Metric - DIY Audio Kit
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 22nd June 2012, 09:11 PM   #4
jean-paul's Avatar
That seller should be on a blacklist.
It's only audio
Old 22nd June 2012, 09:25 PM   #5
Hey I bought some capacitors no too long ago and they blown like pop corn. I tried 2 with the same resulted. At the beginning they started to get sponged, hotter and then they blown up. I trashed all 12. They looked same as your after they blow up. Save those for the 4 of July.
Old 22nd June 2012, 09:53 PM   #6
jean-paul's Avatar
It goes to show that E*ay brought the hobby good things but quite questionable stuff as well. Not the fault of E*ay of course but it is not the same as an official distributor of brand stuff. I would buy large can caps from a normal distributor just to be sure.
It's only audio
Old 22nd June 2012, 10:14 PM   #7
Enzo is online now Enzo  United States
I never buy parts on ebay, this is one of the good reasons.
Old 22nd June 2012, 10:23 PM   #8
The OP bought the parts from a dedicated webshop, not ebay. Yes ebay is an easy outlet for sellers of fake parts, but to say that one should never buy any parts on ebay because they're all fakes is a little extreme.
Most of the time it's pretty easy to get an idea if the parts you are buying have a high chance of being fakes or not, you just have to pay attention and maybe do a little research.
Old 22nd June 2012, 10:31 PM   #9
I bought a good number of vacuum tubes on Ebay, and haven't had much problem - there was one tube that looked used that was described as NOS, but the seller was only asking about 5 bucks, so I didn't complain.
Old 22nd June 2012, 10:33 PM   #10
UV101 is offline UV101  England
UV101's Avatar
They look very dubious to me. There is a reason that the cheapest decent caps are about £10 each for 63v 22kuF! I suspect I've had fake LM3886's and a short lived CS8412 all in kits from china and my green dac from Analogue metric has some very dubious looking nichicon fine gold smoothers!!!
Never buy caps direct from china, its just far too easy to print heatshrink and sell ant thing on as "For Audio" etc. I suspect that the heatsrhink is on the wrong way round and you've connected that cap in reverse. You should remove the other caps and check the markings on the solder tags to see if the wrapper was the right way round.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
WANTED: 10,000 to 33,000 uF caps - 80V or higher Coconuts 500 Swap Meet 5 23rd April 2011 12:40 AM
Looking for 10,000+uF / 80-100V caps quicknick Swap Meet 7 4th September 2010 07:47 PM
22,000 uF/ 50V Caps/ 4 terminals/ for sale lgreen Swap Meet 4 15th December 2009 09:26 PM
10,000 uF Panasonic Caps (UK) for sale chris-man Swap Meet 5 14th July 2005 06:07 PM
Free 6.3V 10,000 uF caps kneadle Swap Meet 2 29th January 2005 02:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
