Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th July 2011, 09:27 PM   #1
Default How to measure capacitor with a basic digital multimeter?
I need help from peopple understanding better these things. So, I would like to measure for example the capacitance of some capacitor. How should I do that? How about tolerance, is it even possible? What about resistors, how to measure the resistance and tolerance?
Thank you in advance for helping me stupid..
-Kimmo-
Old 28th July 2011, 09:32 PM   #2
Did it Himself
richie00boy's Avatar
Most basic multimeters cannot measure capacitance. They do amps, volts and ohms.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 28th July 2011, 09:57 PM   #3
A multimeter measures what the capacitance is, or the resistance. If you measure enough of similar ones and know what value is they are branded, you know the tolerance of the batch.
vac
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall.
Old 28th July 2011, 10:04 PM   #4
sofaspud's Avatar
You can measure larger value caps with a 12.6V or 6.3V filament transformer, an AC voltmeter, and a 50k potentiometer. Put the R and C in series with the secondary and apply mains voltage to the transformer primary. Adjust the pot until the voltage drops across the R and C are equal. Disconnect and measure the resistance of the pot. Then C = 0.159/f*R, where C is the capacitance, f is the line frequency, and R is the measured resistance of the pot. A capacitance meter is much easier, especially for smaller value caps. Every multimeter will measure resistance.
Tolerance isn't really measured because it is a range. It is the amount that the component will vary from the specified value, ie a 5% tolerance 100 ohm resistor should measure between 95 ohms and 105 ohms.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 28th July 2011, 10:39 PM   #5
sofaspud's Avatar
Another thread here took me to Conrad's page for a capacitance bridge. This is an expansion of my procedure above, and provides for a wider range and more accurate measurement.
Old 28th July 2011, 11:09 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
Originally Posted by sofaspud View Post
Adjust the pot until the voltage drops across the R and C are equal. Disconnect and measure the resistance of the pot. Then C = 0.159/f*R, where C is the capacitance, f is the frequency, and R is the measured resistance of the pot. A capacitance meter is much easier, especially for smaller value caps. Every multimeter will measure resistance.
You can also do this much simpler with a soundcard, a dead pair of headphones (for the cord, plug it into your PC speaker out), a fixed resistor (8-10 ohms) and a multimeter.
hook the resistor and capacitor in series on one channel and do as sofaspud recommends. Vary frequency using a tone generator program until the voltage drop is the same and calculate C.
Tolerance in percent is simply 100 x (M-V)/V
M=measured value
V=specified value
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Digital MultiMeter? nelsondog Everything Else 23 28th August 2010 10:42 PM
need help with getting a digital multimeter ad_breaker Parts 14 19th February 2006 02:13 AM
How to measure a Triac with a multimeter? Charles Hansen Parts 3 1st September 2005 02:25 AM
Digital Multimeter speedstar Digital Source 2 20th July 2004 02:56 PM
Page generated in 0.08952 seconds (73.29% PHP - 26.71% MySQL) with 10 queries
