Top quality main switches for audio-hifi comp (Rotary and Pushbutton Power Switches)
If I use AC power cables for main connection like this about
NBS OMEGA CABLE PRICING
I must use also absolutely high quality main power switches.
But this one are hard to find.
Here a little overview:
A. Rotary Switches
1) Saia-Burgess
Saia-Burgess P5-1N-209
Saia-Burgess | Relais, Schalter und Anzeigen | Schalter | Drehschalter | Frontplattenmontage, für 230 V AC |P5-1N-209
Saia-Burgess TH508025000
Saia-Burgess | Relays, Switches and Indicators | Switches | Rotary Switches | Panel Mounting, Signal |TH508025000
2) Lorlin
Lorlin RMS1016
http://www.lorlin.co.uk/pdf/RMS.pdf
Lorlin | Relays, Switches and Indicators | Switches | Rotary Switches | Panel Mounting 230Vac Rated |RMS1016
3) Shallco
Shallco - Detented Power Switches 15 Amp
Shallco - Series 16 Rotary Switch 15 amp Single-Hole Mount
http://www.shallco.com/images/4holgrpb.jpg
http://www.shallco.com/images/16b.jpg
But I don't a delivery source
4) Various
Miscellaneous Rotary Switches
B. Pushbutton Power Switch
1) Panasonic ESB92S/D
Electromechanical Components - Power Switches
http://rocky.digikey.com/weblib/Panasonic/Web Photos/New Photos/ESB-92S21B.jpg
http://rocky.digikey.com/weblib/Panasonic/Web Photos/New Photos/ESB-92D21B.jpg
2) E Switch P227
power pushbutton switch | push button UL listed | multiple options | www.e-switch.com
http://rocky.digikey.com/weblib/E-Switch/Web Photos/P197SBEE.jpg
3) Toneluck (often to find in some harman models)
http://www.toneluck.com/pdf/pwl-2p.pdf
http://www.toneluck.com/pdf/pwl.pdf
4) Legion
Push Button switches | Lectronic ElectronicC Co., Ltd.
5) Apem IT 40 Series
Pushbutton Switches
http://www.apem.de/files/apem/brochures/DEU/Netzschalter_IT-DEU.pdf
6) ITT-Canon (C&K) NE18 ("NE 18")
C&K NE-18 Series Mains / Power Switches
NE-18, Pushbutton By C&K Components
7) Various (OEM)
Switchs mail order for Televisions etc, also tack switchs for computers etc.
http://www.pltv.org.uk/pictures/sw629.jpg
Of most models I don't know what is here to prefer and to avoid.
Thank you very much for your comments.
The decisive factor here will be the quality of contact material that need to process the voltage flash of inrush currents - especially by large main transformers - so I think.
A plain 10A relay works better than any switch I know of, so why use a switch?
Magura :)
For new projects the royal way. But to replace cheap and worse versions in existing audio components against that one of higher quality usually associated with too much trouble causes through various modifying.
Therefore I prefer there the kind of switches mentioned at post #1, but in "long life" and high quality versions.
Dagen: Honeywell AML34/36 is a good advice - thank you
Push-button switches of excellent quality are manufactured by EAO in switzerland. Their series 04 offers even aluminium front rings and buttons. Hard silver contacts for high reliability and high current rating. Nice parts that make the use of auxiliary power supplies to power relays completely unnecessary.
Contact EAO and ask for their nearest dealer as EAO is not available at the common distributors.
Have fun, Hannes
Contact EAO and ask for their nearest dealer as EAO is not available at the common distributors. Have fun, Hannes
This is the brand, inside by old Naim Audio power amps like NAP160 and NAP250 (formerly LUMITAS as I know). Expensive, but I must never replace this switches by service - therefore one can assume very high reliability and life time.
Pushbuttons, push buttons, 8mm 16mm 22mm Push button switches, illuminated switches, LED pushbuttons
Thank you for this advice.
Thank you for this advice. This kind of switch are the so called "Rocker" - or "Paddle" switches. From this switches there are to find the widest range of brands. Therefore, I have not included these manufacturers in the overview here.
Especially in cases, where arises very high inrush current peaks while "switch-on" (large toroidal transformers without inrush current limiting e. g.) I need very robust switch contact materials to enhance the lifetime and reliability.
What brands of rocker (paddle) switch are here the highlights? The optical outline by such switches are the same than by that one in cheap version - therefore the highlights are hard to find for me.
  • Magnecraft Relais W199AX-9,.pdf
A. Rotary Switches
1) Saia-Burgess
Saia-Burgess | Relais, Schalter und Anzeigen | Schalter | Drehschalter | Frontplattenmontage, für 230*V*AC |P5-1N-209
2) Lorlin
Lorlin RMS1016
Page not found - Lorlin Electronics
3) Shallco
4) Various
2) E Switch P227
4) Legion
Pushbutton Switches
7) Various (OEM)
Any news?
in this case I have found this company:
http://www.doduco.net/en/doduco/products-services/contact-rivets.aspx
Updated overview:
A. Rotary Switches
1) Saia-Burgess
P5-1N-209 | Drehschalter 15A 250VAC normal | Saia-Burgess
Saia-Burgess TH508025000: nla
2) Lorlin
Lorlin RMS1016
https://www.lorlin.co.uk/wp-content/uploads/2017/09/RMS-ROTARY-MAINS-SWITCH-GB-Iss-A-190917-1.pdf
RMS1016 | Rotary Switch, 2 Way, Solder | Lorlin
3) Shallco
Shallco Inc > Industrial Switch Products > Detent Action Rotary Switches and Lock-Out Relays
http://www.shallco.com/portals/0/industrial/detentactionrotary/Series-16-Switches.pdf
http://www.shallco.com/portals/0/industrial/detentactionrotary/Series-26-Switches.pdf
4) Various
https://www.surplussales.com/Switches/SWRoMisc-2.html
https://manualsbrain.com/de/manuals/1103543/
https://www.digikey.de/product-detail/de/panasonic-electronic-components/ESB-92S21B/P8100S-ND/259552
4) Legion MPS11 series
http://legion.com.tw/en/products-MPS11.php
http://legion.com.tw/products/download/MPS11.pdf
5) Apem A1/AO3 Series
https://www.apem.com/int/a1-series-43.html?search_query=IP40&results=5
https://www.apem.com/int/a03-series-50.html?search_query=IP40&results=5
https://www.ckswitches.com/products/switches/product-details/Pushbutton/NE-18/
https://www.ckswitches.com/media/1409/ne18.pdf
7) Various (OEM)
8) EAO 01 Series
http://products.eao.com/index.php?IdTreeGroup=1076
C. Toggle Power Switch
NKK S732-RO
http://www.nkkswitches.com/wp-content/themes/impress-blank/search/inc/part.php?part_no=S732
D. Rocker Switch
1) Carling Technologies C1005B Series
http://www.carlingtech.com/thermal-cb-c1005b-series
http://www.carlingtech.com/de/thermal-cb-c1005b-series
2) Cherry WR Series
https://www.jameco.com/Jameco/Products/ProdDS/577643.pdf
3) Honeywell AML34/36 Series
https://sensing.honeywell.com/AML34FBA4AC01-pushbutton-switches
https://sensing.honeywell.com/index.php?ci_id=142059
4) E.T.A. 3120
https://www.e-t-a.de/produkte/schutzschalter_sicherungsautomaten/thermische_schutzschalter/p/3120/
https://www.e-t-a.com/uploads/prodb/D_3120-Wip_e_230209.pdf
The decisive factor here will be the quality of contact material that need to process the voltage flash of inrush currents - particularly by large main toroidal transformers without inrush current limiter - so I think. Therefore the contact material is very important. Which of the follow is here the best ?
Ag & Ag Alloys
Ag/Ni
Ag/SnO2
Ag/ZnO
Ag/CdO
