those figures aren't real bad for half space - its 15.5" deep by 17.75" wide by 48" tall. Ask some of the guys real good with hornresp in the subwoofer forum to model some tapped horns and tapped TQWT-s for that B&C - if you already own then might put it to use - it looks like a high fidelity unit as a direct radiator.
here's an old thread at Speakerplans where I got the idea for the pipe and the aperture - look at the simulations - they should help you get an idea on how to use hornresp for this case.
Plan ! - D-20 (hz) Macro Sub ..tapped horn by moi. - Speakerplans.com Forums - Page 1
thank you freddi
is very compact
high fidelity unit naaaaaaaa
I am doubtful because until now these woofers have been disgusting...
I really hope that this woofer will suond better with these boxes
however, I want to do a test and throw 45 euro to build a test box...
I keep you informed
thanks to all
new photo!!!
This is the place where we will do aperitif this summer
Saturday I spent a day to pass a cable 3x10mm^2 (26m lenght) for powering the amplifiers
the cable is directly connected to the differential relay
from the relay to the main cable of 20mm^2 there is a cable of 6mm^2 (0.5m lenght)
the cable passes in a corrugated under tiles
I intercepted it in a well and I made a cassette with an industrial socket
Now the subwoofer has a sound much more clean and precise
Now the 12" mid-woofer are not keeping up with the subwoofer
A pair of 12" Mids can't keep up with a pair of 15" bass speakers ?.................Now the 12" mid-woofer are not keeping up with the subwoofer
truly incredible, the excursion becomes too much of the mid-woofer and amplifier goes into clipping frequently (only the led lights, the sound is normal)
evidently the sensitivity of the sub is too high
https://www.youtube.com/watch?v=5knR89_n52Q&feature=youtu.be
next Sunday I try to record with a microphone
- Live Sound
- PA Systems
- choose the best loading for professional woofer
