The "Elsinore Project" Thread
Old 27th March 2011, 01:03 AM   #771
spoonted is offline spoonted  Australia
Originally Posted by rob323 View Post
Proof of concept.
I was wandering if rob323 or someone else has finished there hamlet project.
I,m very keen to make some based on MK5 version.
Cheers
Old 28th March 2011, 04:20 AM   #772
Joel Wesseling is offline Joel Wesseling  Canada
ALUMINUM WAVEGUIDE
Have to take back for recessed screw holes. should be fine for machine screws as well. wood type screw for plywood is good but not so good for MDF
Old 28th March 2011, 01:41 PM   #773
My Elsinores, i,ll have a go at veneering them later.
Old 28th March 2011, 02:36 PM   #774
kingfisher is offline kingfisher  Canada
Default waveguide
Hello Joel, I posed a similar suggestion to Joe on this same dilemma, the back portion to match the tweeter flange contour. It was to think of the tweeter flange as an inclusive part of the waveguide and not something that mounts to the guide. In this respect one could first machine the back face that would accept the tweeter in the same fashion the tweeter accepts the (original Peerless) flange, and by doing so the plate (aluminum) can be flipped back over to machine the mouth, throat and flare at the exit. This I think will eliminate the additional attention to the tweeter/flange matching the guide. In essense the tweeter (without flange) would mount directly to the waveguide!
I could include a drawing if you do not see the image in your head!
Francis
Old 28th March 2011, 02:55 PM   #775
Default waveguide
Hello again Joel, I was a little to anxious to reply to this post as the images were slow to come online! It appears you have the fix already. Good work. With that said I would like to be on the list to order a pair! Sorry for the mix-up!
Francis
Old 29th March 2011, 08:38 AM   #776
Joe Rasmussen is offline Joe Rasmussen  Australia
Joe Rasmussen's Avatar
Hi Guys
With some help from Spoonted, this is the latest crossover. With certain source material with consistent bass below 100 Hertz R2 can get quite hot. So it should be a minimum rating of 10 Watt.
AMENDED CROSSOVER:
The "Elsinore Project" DIY Speaker System & DIY "Trans-Amp" - 40 Watt Transconductance Amp
- "Don't take anything I say as an affirmation, but as a question." Niels Bohr
Old 29th March 2011, 09:05 AM   #777
Cheers
I would need a pair of the boxes here fitted with the drivers - then add Waveguide and then do a significant amount of work - the drivers are measured in situ, both electrical acoustic measurement, all which are imported into computer modelling where the initial crossover can be developed. Then the crossover needs to be physically constructed and tested and additional changes needed from there. Naturally we are talking about listening and then matching the tonal balance of the Elsinores.
We could call the Hamlet Mk5 so that it is apparent it matched Mk5 Elsinores.
So... needs to see the boses... ?
Cheers, Joe
Old 29th March 2011, 09:11 AM   #778
Originally Posted by panord View Post
Anyway, my question is a simple one, I think. I currently have the crossovers in an external box. I would like to move them inside the cabinet so I can clean up the wiring and eliminate a connection...
A number of people have fitted the crossovers to the bottom of the box. While I prefer external because it makes it easier to work and tweak them, doing it internally is OK by me. Some may point out that external crossovers see less vibrations, that is true, but I wouldn't make a big issue out of it.
Cheers, Joe
Old 29th March 2011, 12:04 PM   #779
Francis
It will take some time but I'd like to see the first pair finished. Nice paint coat. Fitted in filler board
At this point I could take the orders and have them made and painted all together
Unfortunatley the weight of AL is more than I guessed. The total will be more like 2 or 3 KG
Planning a Hamlet build for center so extra Waveguide is needed. Hopefully the new xover will come out.
Joel
Old 30th March 2011, 09:12 AM   #780
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Joel
Hi Joel, can you paint aluminium? I thought aluminium is anodised.
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
The "Elsinore Project" ThreadHide this!Advertise here!
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
A thread to post your "project files" critofur Multi-Way 10 21st March 2008 12:50 PM
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
The "Really simple and cheap speaker designs for the newbie!" thread. Spasticteapot Multi-Way 5 19th March 2006 04:16 AM
