I'm partial to tung oil on birch.
I dilute the first coat with at least 50% mineral spirits. Then I make it progressively stronger with successive coats and finish with full strength. It comes out a lot less blotchy that way.
I am so sorry...I meant to say MINERAL SPIRITS. If a moderator is available please edit my previous post.
SveinB,
I have not used tea or wine to stain wood but ordinary stains(Minwax etc.) will work after the sealer is applied. End grain is always a problem; I try to apply one coat to the end and several to the rest of the cabinet to try and match these areas. I don't sand between stain coats. You also can mix your stain with the sealer. I prefer to apply the sealer until the wood will not accept any more, let it stand about ten minutes and wipe off the excess. This prevents heavy sap woods like pine from becoming blotchy when staining.
Again, I apologize for the error in my previous post.
Ray
Hi, Ray -
Unrelated, but I just noticed that your online name is the same as that of the actor who played 'Lieutenant Tragg' in the Old Perry Mason TV show.
Hi, Ray -
I might note be sounding too constructive here, but ... now, this was three full years ago! Honestly, do you really expect Ray Collins to answer? I'd be surprised. But, again, I appreciate new input. 😉
