#2 |
The 801's use a Bessel 4th order alignment, basically
overdamped, but well suited to typical room gain. The classic way of re-aligning is a 2nd order high pass filter set at the port frequency with Q adjustable between 1 and 2. For a non-vinyl system with no subsonic rubbish, its also possible to use a low bass shelving circuit, which has better transient response, this can be entirely passive at line level, as maximum loss would be 6dB. Design of either approach is fairly straighforward. |
#4 |
do you mean to say "all pass" filter for time alignment? Here's the design which Ballard used in his 1982 Speaker Builder Article with "virtual instruments" thrown in -- the output of the filter lags the input by 50uS.
#5 |
I used this for several years. Same target as B&W's box.
| Qualitative variable bass humps – digital EQ v alignment, freedom from compression | rick57 | Multi-Way | 6 | 4th April 2007 12:49 PM |
| bass filter | mlkirchgessner | Car Audio | 3 | 1st March 2007 02:52 PM |
| Bass beat filter | malc c | Everything Else | 9 | 2nd January 2007 09:57 AM |
| Which filter alignment for sub... | JojoD818 | Solid State | 2 | 13th October 2003 02:13 AM |
| T+A T160E bass XO reverse engineered -> improvements? | capslock | Multi-Way | 7 | 12th August 2002 11:35 AM |
| Page generated in 0.12839 seconds (52.78% PHP - 47.22% MySQL) with 11 queries |
