Old 1st May 2004, 04:09 PM   #1
dewdrop is offline dewdrop  Singapore
Default Replacing the caps in the crossovers...
I would like to replace the capacitors in my Totem Model 1 crossover in hope of a better sound.
Can anyone advise on this?
Thanks!
Ed
Old 1st May 2004, 04:39 PM   #2
Bill Fitzpatrick's Avatar
They already have polypropylene bypassed with polystyrene - a difficult combination to beat.
Old 1st May 2004, 04:45 PM   #3
diyAudio Senior Member
fdegrove's Avatar
Does anyone know what polys they used?
TIA,
Frank
Old 1st May 2004, 05:42 PM   #4
Hi Bill,
Thanks for the info, did you know any other mods on the speakers then?
Ed
Old 1st May 2004, 05:45 PM   #5
Personally, I wouldn't change a thing.
Old 1st May 2004, 05:48 PM   #6
Recently, I found that positioning the speakers to provide a full-bodied presence for the vocals is pretty difficult. I tried w/o toeing-in the speakers and it was terrible.
How do you place yours?
Ed
Old 1st May 2004, 06:05 PM   #7
I don't own these speakers and have never heard them.
Old 2nd May 2004, 03:08 PM   #8
If you must this may help :
http://home.hetnet.nl/~geenius/CAP.html
but I'd regard the Totem's are well optimised and suggest
you'd probably be wasting money on expensive capacitors.
sreten.
Old 2nd May 2004, 03:10 PM   #9
trigon's Avatar
Where can I get Vishay Roederstein MKP1837 10nF either here in NorthAmerica or elsewere?
Thank you in advance.
Trigon.
Old 19th February 2006, 01:48 PM   #10
The Totem Model 1 are using Solen caps with polysterene bypass. The tweeter is using a 3.9uF caps which I planned to change to Mundorf Supreme or the Silver in Oil.
This will be my next upgrade.
Replacing old caps in the SP8 pre-amp enilsen Tubes / Valves 6 7th February 2010 07:02 PM
Replacing multi-section caps with multiple caps? Sir Trefor Tubes / Valves 1 29th May 2007 10:17 PM
Replacing electrolytic caps in crossovers - what voltage rating to use? Ruach Multi-Way 6 30th November 2005 07:30 PM
Anybody out there replacing high-end speaker's passive crossovers with active ones? wigginjs Multi-Way 13 13th May 2005 01:55 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Page generated in 0.26401 seconds (30.12% PHP - 69.88% MySQL) with 10 queries
