I just replaced the 25 ohm pots on my stock N-800-F crossovers because the originals were non-functional. Unfortunately, I replaced the called for 25 ohm pots with 25K ohm pots. Needles to say, they are also non-functional. I have a couple of 16 ohm L-pads but I am unsure how to wire them up in place of the stock pots+20 ohm resistors. I'm not smart enough to interpret the schematic for an L-pad and then transfer the correct wires from the pot+resistor.
I'm trying to get this done for Christmas!
Any help appreciated.
Hi WntrMute,
This isn't really an L-Pad, just an attenuator.
What most fussy people do is replace that with a string of resistors. Depends what you have and what you have time for, because at this point the value you want you'll have to experiment with. I'd suggest getting a 5 and pair of 10s. Put them in series with R1 to (+). Then connect the wiper, or the arrow from the end of L1 to each in turn until you get the right level. So maybe like this:
--10--5--10--
Then depending on where you put the wiper (L1) you achieve different levels of attenuation. The order of the resistors doesn't matter. So you could do:
--10--10-5--
or
--5--10--10--
What matters is you get the level right. The 5 Ohm resistor will give you a good half-way point. You can then attach the wiper at any of these points on the series of resistors. For instance:
--5-^--10--10--
Would give you just a little attenuation (5 Ohms) while putting it one step after:
--5--10--^--10--
Would increase the attenuation a little more. Jumper cables are your friend.
You could also put the wiper (end of L1) at the beginning or end. Depends what you need.
Best,
E
--10--5--10--
--10--10-5--
or
--5--10--10--
--5-^--10--10--
--5--10--^--10--
Best,
E
The problem I'm having is that in that schematic, you don't have an L-Pad. You have a pot.
That's why I'm confused, and suggested what I did.
In general though, the middle pin is the wiper, or where the arrow from L1 goes.
Best,
E
I'm confused as well. That is why I was posting the question.
Normally they are produced with the arrow (the tap) in the middle (where you have three contacts in a row). As far as the other two connections, in this particular situation you could probably use it either way.which wires/resistor in the original design go to which contact on the new pot
If I understand you. The middle tap on the L-Pad gets the two wires (blue & black) that are attached to the middle tap in the picture. The single black wire goes to one tap, either 1 or 3. The 25 ohm resistor gets bypassed by a wire that goes from the last tap to the tag strip. In essence, removing the resistor from the circuit. Sound correct?
Thanks for your help with this.
Yes. You mention bypassing the 20 ohm resistor and I assume you mean to effectively remove it. Have the two new resistors add up to 45 ohms or so.The middle tap on the L-Pad gets the two wires (blue & black) that are attached to the middle tap in the picture.
The action of the pot in the original crossover is going to change more than the level, just slightly altering the response character, so there is some uncertainty to begin with. A little experimentation is in order.
- Help with L-Pad
