SEAS A26 build
SEAS A26 build
Old 14th March 2017, 04:33 AM   #71
bk856er is offline bk856er  United States
bk856er's Avatar
SEAS A26 build
Xaborus not to worry - no offense taken and very happy to read your informative post. That's the beauty of diy - make it how you want and be in charge. Then make it again if you want to try it a different way. Get valuable input along the way from helpful folks who've been around the block a time or two.
Dig that transparent black look. So many options.
BK
Old 19th March 2017, 01:31 PM   #72
zman01 is offline zman01  Bangladesh
SEAS A26 build
Any weekend listening updates so far?
Old 19th March 2017, 11:08 PM   #73
bk856er's Avatar
SEAS A26 build
Too early for meaningful impressions - still adapting and haven't cycled in other amps yet. There was definitely a change in the first 2 days and right now I would not call it warm at all. Think I will need to try the 12ohm resistor and stuffing quantity. Will say that I turned it up to 11 last night to show it off for some youngsters and it certainly does impress at high volumes!
BK
Old 20th March 2017, 02:34 AM   #74
stellablues is offline stellablues  United States
BK
Does this first impression mean its good but not great so far?
Old 20th March 2017, 03:25 AM   #75
bk856er's Avatar
SEAS A26 build
I think they're beyond good and maybe even great. But I want to spend more time getting to know them with various configurations. Changed the amp tonight and I'm getting some new character. For sure, the mid/tweet is a star.
BK
Old 20th March 2017, 11:18 AM   #76
anji12305 is offline anji12305  United States
Position near the rear wall, and proximity to the side walls will influence tonal balance, reinforcing LF.
The big woofer is pretty stiff, out of the box. A couple hours fiddling around will get you sorted...
Old 30th April 2017, 02:43 AM   #77
Xaborus is offline Xaborus  United States
How about an update on impressions?
Old 30th April 2017, 04:19 AM   #78
theaudiopath is offline theaudiopath  Australia
Part of the reason the A26 design works with such a low Crossover and such a simple one is the use of a 1.5 inch tweeter. They have the right acoustic output where you need it. The only one I could suggest other than the Seas is the Audax TWO34 XO 1.3 dome.
I say don't mess with it. The simple elegance of the design is part of its appeal.
Old 30th April 2017, 04:28 AM   #79
akarma 76 is offline akarma 76
How does A26RE4 looks like compared to old 25F-EW? It would be interesting to compare...
Old 30th April 2017, 04:31 AM   #80
bk856er's Avatar
SEAS A26 build
They keep getting better
Been using them daily since I hooked them up and the initial build euphoria has not worn off at all. Still need to connect up some key amps and torture test. The larger A26 is blocking vertical growth of my tower of diy electronics, so need to shuffle things around. One thing I find particularly impressive is the quality when the volume knob is twisted to the right - and this from a humble Wiener Pro. Super smooth and non-fatiguing.
More when I can, driven by Pass designed M2 clone and VFET, and hopefully also even an F6.
BK
SEAS A26 buildHide this!Advertise here!
Seas A26 speaker? bk856er Pass Labs 35 22nd January 2018 03:32 AM
SEAS A26 Speaker Kit HiFiHarry Multi-Way 62 28th December 2017 06:07 AM
time align the seas a26 kit ? norman bates Multi-Way 11 29th September 2016 05:09 AM
SEAS A26 crossover frequency nugat Multi-Way 5 7th June 2016 07:04 PM
SEAS A26 in oversize cabinet nugat Multi-Way 8 16th May 2016 04:04 PM
