for the same price of the sb you can get woofers like alcone that will behave much better when pushed hard , but the op seems fixated on the sb
I have bought the SB, how much cost the alcones?
same price 100€
http://www.lautsprechershop.de/index_hifi_en.htm?http://www.lautsprechershop.de/hifi/alcone_en.htm
they have better power handling 100Wrms 90db, and sound quality is good too , i own a pair
for the same price you have the seas but sensivity is lower 86.5db
http://www.europe-audio.com/document.asp?document_id=1725&link=datasheets\seas\L22RN4X-P.pdf
pro woofers with high sensivity should be ok with your 40w amp. what i dont understand is why you want to use 75w amps for tweeters and 40w amp for woofers , makes no sence to me regardless of amp being class a or a/b
OK make sense I will try 75W to woofers and 40W for the midwoofers + tweeters, what do you think of the active Xover for the woofer?
I´ve never seen or used that active xover you have , if it doesnt mess up the source signal too much , should be ok.
If is necessary only changing 4 resistor can be modified for higher output voltage.
3V is enough unless you use pro amps that require more output , my minidsp only outputs 2v and i never use it at max volume
- Help for 3 or 4 way loudspeaker
