Old 14th September 2007, 09:34 AM   #1301
Yes I'm using the Aleph 1.2 mono blocks on the top and a Hafler 9500 on the subs. The two sound great together. I used the same amp setup on the Legacy Focus when they were in the system also.
Steve F
Old 24th September 2007, 01:39 AM   #1302
Send a message via MSN to Toast_Master
Hey people
This is my system
The only Diy item here is my subwoofer my main speakers are AAD C-800i, my center and rears are DSE bookshelf speakers and my amplifier is a Zensonic Z1080B 7 channel amp
Old 24th September 2007, 03:39 AM   #1303
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Toast_master, those subwoofer drivers look like car subs.
...still looking for the holy grail.
Old 24th September 2007, 03:52 AM   #1304
They Car subs lol
Alpine type R 12" dual 4 ohms
Old 24th September 2007, 09:01 AM   #1305
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Originally posted by Toast_Master
They Car subs lol
Do they make any low bass? That sub looks very nicely built and finished, although surely it'd be nicer with the plate amp screwed into the back or side.
Simon
Old 24th September 2007, 10:10 AM   #1306
Simon
Do they make any low bass?....Oh you, you think just cause there car subwoofers that there not capable of low bass, Car subs usually have tiny boxs and as you can see I gave them a decent sized box,
and yes can they produce "low" bass, try 20 - 80hz +/- 2 db outside, A little more mixed up inside but yeah, its a sweet subwoofer and because there car subs they are tough and durable
and in my room There must be a room mode at 16hz because I can hit 110 quiet easily lol, shakes my walls and throttles the towl shelf on the other side of the wall
Also I would have preferred to have the plate amp on the inside but thought it out and Kept it out just in case I sold it to a car owner and they chose to use it in there car, so I stuck bi-wire terminals on the back
If you want to read about it, search "Dominator"
thanks cya
Old 24th September 2007, 10:15 AM   #1307
SimontY's Avatar
Yeh, that's what I thought. But like you say, the box size you've achieved is totally unlike what people have in their cars, and clearly that allows things to work properly. I did think many car sub drivers were optimized for mid-bass, but you've chosen decent ones if you can get sub-20hz! (Low bass is usually considered 16-40hz.) 110db is very loud!
edit: is it just me or has anyone else noticed every Aussie on this forum loves extreme bass??? lol
Old 24th September 2007, 10:35 AM   #1308
Hey
yeah there quite Awesome thanks, they do the job well but I will admit Id have preferred Tempest subs but the adire shop would not reply to any of my emails at the time, so I had to find some subwoofers of decent quality that had nice Xmax
Can I see a pic of yours and some specs? I viewed this thread thinking there wouldnt be that many pages I checked the first few but I wanted to post mine so I skipped over the rest lol but will look later
Thanks Cya
Old 24th September 2007, 10:41 AM   #1309
SimontY's Avatar
Sure, I can post a pic, but it'll have to be when I get home. My Tempest isn't that special, although it is large: 270 litres, ports tuned to 20hz (2 x ~10cm diameter ports). Driven by a decent class D plate amp of 150w: plenty in this large box.
I find the Tempest isn't so great for anything above 50hz, but it's crossed over at about 45hz so all it does is fill in a bit. I mainly use it for music. If I wanted a sub to go higher it would have to be in a much smaller & sealed box, otherwise I don't think it can be made to gel.
For home cinema I run it full range and allow a processor to send LFE to mains and sub jointly. This gives a good wallop.
There are some terrific bass solutions in this thread if you have a good browse!!
Simon
Old 25th September 2007, 08:55 AM   #1310
David Gatti's Avatar
Default New rack
Here're some pics of a new equipment rack I knocked together.
The shelves are 1" plywood and the sides 1" MDF. Wheels on the bottom make rear access a lot easier, thankfully.
Cheers
David
www.gattiweb.com
Copyright ©1999-2013 diyAudio
