Adding a super tweeter to a full range - Page 11 - diyAudio
Old 15th January 2013, 08:44 PM   #101
It's crazy how much difference they make. If I am listening to some music and then disconnect the full range driver, the actual sound coming from just the tweeter doesn't sound much at all, but by removing the tweeter and leaving just the full range driver seems to remove so much more.
Another project of mine: (a very big one at that!)
http://www.mp3car.com/vbulletin/show...5-pimping.html
Old 15th January 2013, 08:51 PM   #102
tuxedocivic's Avatar
A couple db can be all it takes. The treble knob has proven that to me quite a few times
Old 16th January 2013, 12:49 PM   #103
OK. Here they are.....
The crossover:
The crossover had to be able to fit inside the enclosure, it was a tight fit!
Finished tweeters with custom made cables:
I'm very pleased with the finish and the sound
Old 16th January 2013, 03:02 PM   #104
cogitech's Avatar
Very nice! This thread will be a great reference for anyone wishing to add sparkle/air to their EL70s. If you could add an explicit summary of the crossover, perhaps with a schematic...?
Old 16th January 2013, 05:32 PM   #105
Good idea cogitech.
Here is my crossover design for the Dayton ND20FA-6 tweeters when being used with the CSS EL70 full range drivers:
This gives a second order crossover at around 18600Hz with 12dB of attenuation per octave. The resistors attenuate the tweeter by 6dB.
I feel this works very well with the EL70's at giving that little extra sparkle.
Old 16th January 2013, 05:41 PM   #106
Wish I had a 0.07mH on hand. I've got the tweeter and everything else. I could try it out. I'm satisfied with the treble on mine, but it's fun to experiment. I do have some 0.15mH I could parallel just for trying out. I could then take measurements to, to see the difference.
Old 16th January 2013, 05:55 PM   #107
Give it a try and see what you think
Old 16th January 2013, 06:34 PM   #108
cogitech's Avatar
Originally Posted by portreathbeach View Post
Good idea cogitech.
Awesome!
Just to be clear; You have a single EL70 (4ohm) in each speaker and you are running the tweeter parallel by securing the connectors on the speaker binding posts?
Old 16th January 2013, 06:46 PM   #109
Yeah, I'm using a single 4ohm EL70 in each cabinet and the tweeter is wired to the binding post.
Old 24th May 2013, 03:17 AM   #110
Default Favorite Hi Tweeter Crossover
Here's an example of my favorite crossover to use on a high tweeter or additional tweeter. It keeps the harshness of voices out of the tweeter, but also raises the end of the response curve some, where the tweeter starts to roll off.
I used this crossover to add some 2 inch 8-ohm tweeters to a pair of speakers each with a pair of 2 inch HiVi A2S Fullrange Aluminum cone drivers in them. Each HiVi A2S Fullrange was 8 ohms, so 4 ohms total with parallel per speaker. I added the 8 ohm tweeter only to help where the A2S rolls off at 15khz, and also since the HiVi speakers are low efficiency, the louder tweeter being crossed so high in frequency made them blend right in without being too quiet to hear them, but not too loud to drown out the speakers either. They were VERY transparent, it made the Full Rangers seem to appear to be producing the upper highs, when it's really the tweeters.
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
full range + woofer OR full range + tweeter ? Bigun Full Range 36 30th November 2016 04:09 AM
Alnico Instrumental Speakers+Super Tweeter as an Option for very expensive Full-Range tiefbassuebertr Full Range 55 5th April 2016 12:26 PM
Adding a tweeter to full range gaust Full Range 50 20th November 2011 11:09 PM
Adding Tweeter to Full Range ttan98 Full Range 95 24th October 2011 08:46 AM
Copyright 1999-2017 diyAudio
