I'm interested in room acoustics and thought I might try some room shapes from Louden's ratios found in the link Speaker Dave provided above.
Acoustics Forum • View topic - ROOM RATIOS
I used CARA room simulation software with the exact dimensions given on that page, and also a cubic room of the same volume. Just a completely bare room, nothing but 2 speakers, carpet on the floor and a listener. The results were surprising. If I let CARA pick the best best position for the speakers and listener, none of the rooms are really bad, not even the cube.
I can post some plots and sims, if anyone is interested.
Hello Pano,
Yes it's possible!
Prediction of resonances based on the Rayleigh's formula only predict the existence of the resonances but doesn't predict wher are the nodes of the resonances framework.
This is why such prediction based on the Rayleigh's formula should be associated with the use of such software as CARA.
And that's sometime surprising how a little amount of acoustic treatment can improve a theorically bad room.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Yes it's possible!
No need, I've done it. I've also been in cubic rooms, and neither are great acoustically. However in neither of those was there a choice of placement. The source(s) was fixed in location and the listener pretty much so.
What Jean-Michel mentions is interesting because I started to see this in the simulations.
E.G., in Louden's "best" room there is a deep, sharp null circa 30Hz right in the middle of the room. But if you are not right in the center, you'd never hear it. How this applies to boxes, I don't know.
Where the nodes are certainly makes a difference in a room, I don't know in box.Prediction of resonances based on the Rayleigh's formula only predict the existence of the resonances but doesn't predict where are the nodes of the resonances framework.
The sound of the standing wave has to come out the cone. If I remember correctly a typical cone has approx. 20 dB of attenuation. Highest pressure will be for nodes between the woofer mounting surface and the opposite side (front to back axial). Placing the woofer on that surface away from nodes of the other two dimensions can help.
For example a tall tower speaker with the woofer at the extreme top or bottom will have the most likely standing wave problem, as in a 1/2 wave resonant line.
David
David
