Need help with a xover please... - diyAudio
Old 28th October 2012, 11:59 AM   #1
sideways's Avatar
Default Need help with a xover please...
Hello
I would like to make a passive xover for my Visaton KE25SC tweeter and my Morel HU621 drivers...
I've measured them in the box (15L ported tuned to Fs of the Morel) and the graphs are below...specs for the Morel too...not much needed for the Visaton I'm guessing...8 ohm...Rdc 5.9 ohms...89db...
Any help would be appreciated!!
Thanks!!
Old 28th October 2012, 12:20 PM   #2
system7 is offline system7  United Kingdom
system7's Avatar
The Visaton tweeter has built in LCR correction of Fs resonance, whic is handy.
The Morel looks pretty smooth.
I wonder if you fancy a serial crossover? Reckoned to be good with the right drivers:
Sreten & Speakerman go at series XOs
Your woofer must be quite similar to the Morel CAW 638 though I'd download the specs for comparison. You can check Zobel values here:
Impedance Equalization (L-Pad) Circuit Designer / Calculator
Best Regards from Steve in Portsmouth, UK.
Old 28th October 2012, 12:34 PM   #3
xjr100 is offline xjr100  Europe
Originally Posted by sideways View Post
I've measured them in the box...
Can you export your drivers measurements in some format (txt ?)
Auricap XO, Mundorf, Jantzen capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Old 28th October 2012, 12:38 PM   #4
sideways's Avatar
Hey Steve
Yes...both drivers are very smooth...which I why I wanted to take a crack at a passive
So...are you saying just a network for the Morel and leave the tweeter alone??
Old 28th October 2012, 12:50 PM   #5
system7's Avatar
No, what I'm suggesting is you can omit the LCR circuit on the tweeter in the crossover. It's built into the tweeter.
You might sim this circuit in Boxsim with a 0.6mH W130S 8 ohm woofer. It should be electrically similar even if the efficiency and exact frequency and phase response is different.
http://www.visaton.com/en/literature...ads/index.html
See how it looks.
Old 28th October 2012, 01:05 PM   #6
sideways's Avatar
K...just plugged in those drivers...came out with this for a 15L ported box...
And...isn't this still a parallel network??
Old 28th October 2012, 01:28 PM   #7
system7's Avatar
I just ran it up the flagpole on a serial crossover. It doesn't work because the tweeter is too flat on frequency response to the Fs resonance so you get too much driver overlap and a midrange peak.
Back to the drawing board. For a standmounter with bafflestep correction on a parallel crossover, it's gonna be about 1 to 2 mH slope coil as you are thinking.
Old 28th October 2012, 01:37 PM   #8
sideways's Avatar
So...if I go with that xover in the pic, it would be a good start??
What about just a first order?? Seems like the drivers would be a natural for that!!
Old 28th October 2012, 02:07 PM   #9
system7's Avatar
I was just looking at this 6" morel HU 621 driver. How do they get the low rolloff?
Morel Loudspeakers - Raw Drivers - Woofers
Last time I saw a frequency response like that, it was an 8" or 10" SEAS Excel and Exotic woofer!
Yes, low order could be the order of the day. You could give it a bash with just a coil I reckon. Will mull this over and remind myself what SEAS did with the X2-08 W8 Exotic.
X2-08 EXOTIC W8
Ah, here it is:
Uploaded with ImageShack.us
Last edited by system7; 28th October 2012 at 02:16 PM. Reason: Added SEAS crossover
Old 28th October 2012, 02:29 PM   #10
sideways's Avatar
Well...that was the DEQX measurement in the box that I am using...
The Visaton is good down to 1.5k - 1.8k...would like to use somewhere in there for a xover point...
They both seem to be natural together which is why I wanted to try a passive for giggles
First order seems like it could work!!
I mean there are lots of speakers that use the internal workings of the driver for their natural rolloff point and a cap for the tweeter...Reference 3a comes to mind!!
The Morel runs a bit too high though for that...therefore a first order maybe?? 10uF cap and a .47mH coil??
3 way xover help Chrisssssssss Multi-Way 2 3rd March 2006 12:38 PM
Xover jwatts Planars & Exotics 0 8th February 2005 05:01 PM
Xover Ruben Multi-Way 0 21st October 2003 01:05 PM
Need help with xover!?!? WhiteBoyChriss Multi-Way 3 20th November 2002 07:03 AM
Sub Xover HELP! Axeman Multi-Way 2 5th April 2002 09:11 PM
Copyright 1999-2017 diyAudio
