NaO Note II RS - Page 35 - diyAudio
Old 29th April 2013, 06:38 AM   #341
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
^Yep. I have learned that!
Rudolf (Finke) gives some good advice at his homepage! Go to downlods and open the lower download (in English)
AINOgradient speaker project
Old 29th April 2013, 10:42 AM   #342
john k...'s Avatar
Originally Posted by thomasjefferson View Post
John, with tweeters wired in series pairs at 8 ohms, do you think the MiniDSP miniAMP has enough power for the tweeters? It's rated at 20w x2 into 8 ohms. Above 6 kHz there's not that much power, but I'm not sure if this is enough. It would be convenient to use the miniAMP because it stacks on the 2x8 board and lets you power the remaining 6 channels with any number of 7-channel amps, or else two fewer channels of class-D amp modules.
I don't know. It migh work for th tweeters in series. Depends on how loud you listen. But I prefer to use identical amps on all channels.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 29th April 2013, 07:03 PM   #343
john k...'s Avatar
Comments form a Note II RS and LX521 builder. The inevitable comparison by an independent builder:
In the last few days I was able to complete (at least for listening) both
your speakers and the LX521's.
As far as musicality is concerned, I like your speaker more than the
LX521. The main advantage the LX521 has, is the woofer section. I have
been able to play the LX521 at very high SPL levels. But for general listening
at moderate to semi high levels, I prefer your speaker.
As expected, the SLS woofers can not play as loud as the SEAS units of the LX521. The XXLS woofer option for the Note would go a long way to neutralize that difference but with a significant increase in cost. As I say on my web site, it would probably be better and less costly, to add a couple of self powered subs if increasde deep bass SPL is required.
Old 29th April 2013, 09:26 PM   #344
Was that review posted anywhere online or was it submitted directly to you (and, I assume, SL)?
Old 29th April 2013, 09:44 PM   #345
john k...'s Avatar
It's more just a few comments than a review. It was sent directly to me and I asked his permission to post it on DIY Audio. I have no idea if he sent anything to SL.
Old 30th April 2013, 03:35 PM   #346
gazza49 is offline gazza49  United Kingdom
The sls woofers in this picture are the opposite way round to the ones on music and design website,does it make a difference or can either face forwards
Old 30th April 2013, 06:41 PM   #347
john k...'s Avatar
It make no difference, but if you were to think that it did you only need pull the woofer baffles, rotate them 180 degrees, and load them back into the woofer enclosure. Then the top woofer would be facing forward.
Old 1st May 2013, 08:08 AM   #348
gainphile's Avatar
Makes me wonder what the difference is, as principally both speakers are designed to achieve the same thing.
It would be interesting to see the actual polar plot of LX521 as none is given/available yet.
http://gainphile.blogspot.com
Old 1st May 2013, 09:43 AM   #349
john k...'s Avatar
FYI, the builder did send a photo and comments to SL.
Old 1st May 2013, 10:01 AM   #350
john k...'s Avatar
Different axial SPL target for one? SL retained the high frequency shelf that he used in the Orion. I designed for basically flat axial response. It's a little more aggressive but at DIY NE listeners preferred the flat response of the Note compared to the roll off top of the Orion. Since the Orion also suffers from tweeter bloom while the LX521 should not, I would expect the rolled off top applied to the LX521 to make even more of a difference. It could also have something to do with the crossover between upper and lower mids as the LX521 is a staggered 1st order passive and the Note II recommended configuration is 2nd order active. And perhaps the ScanSpeak Discovery drivers are just better in the midrange. In any even, it's all speculation, based on one listeners impressions.
I'm just please that one independent builder prefers the Note II.
NaO Note preview gainphile Multi-Way 161 19th December 2012 10:53 AM
NaO II RS gainphile Multi-Way 18 7th March 2012 10:28 PM
NaO II and miniDSP john k... miniDSP 27 31st July 2011 11:51 AM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 05:17 AM
RS Labs RS-A1 Tonearm New Unused Boxed mozfet Swap Meet 4 6th September 2004 10:51 PM
Copyright ©1999-2017 diyAudio
