rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 25th January 2013, 10:39 PM   #361
kgrlee is offline kgrlee
Originally Posted by Barleywater View Post
For tweeter in previous post paired with upward firing woofer of Pluto type speaker above 23cm measurement is used for making both IR measurements.
Presumably, you can get both your ears at this point for both left & right speakers.
MLS as sampled measurement system doesn't return a sync function. Pure correlation. Swept sine measurement over full band can also return near perfect correlation when at least partially constructed in the frequency domain.
Are you saying when you use a MLS system and import the results into Aurora/Audition, Angelo's Kirkeby module produces an end result which is a perfect impulse? Can you post some results?
What MLS or swept sine system are you using?
If you set the 'error' in Angelo's 'Kirkeby' to a very small value, you should minimize the 'sync' character. This is more a 'feature' of the 'Kirkeby module' than of Angelo's measurement method.
[/QUOTE]So what sweep pair would you generate with Angelo's gensweep to measure the above Peerless 2" driver?[QUOTE]I don't use Aurora cos I can't afford Audition. I've just downloaded the Audacity version but have still to try it out.
Adjusting the start & end freqs of the sweep will affect the "final impulse".
Here are some spectrums of log sweeps I use that illustrate the end effects. I use my own software. These affect the accuracy of the "final impulse". The final artifacts appear at half Nyquist as would be expected. Short chirps to accentuate the effect. For the 2" driver, starting the sweep at 100Hz is probably OK. I would use a sweep speed to give the dulcet tones of a 14s B&K 2307 chart recorder sweep cos that's what God intended.
But you may like to actually measure the "final impulse" separately rather than look at processed results. It's easy to make processed results "perfect".
Old 28th January 2013, 10:40 AM   #362
more10 is offline more10  Sweden
Guys, those discussions are really interesting (I mean it), but I would prefer to keep that thread a little bit more focused on rePhase if possible. As it is now a user of rePhase would have difficulties to find any relevant information on the use of that software in that thread.
Ask moderators to rename this thread to "rePhase OT", and start a new one.
Old 28th January 2013, 12:51 PM   #363
CopperTop is offline CopperTop  United Kingdom
Just adding an 's' to the end of the thread name would do it...
Old 28th January 2013, 01:36 PM   #364
Pano is offline Pano  United States
Pano's Avatar
When I get a chance, I'll look into clean up and splitting the thread. It would be nice to keep this one ON topic.
This thread really should be in the Software section, anyway.
Old 28th January 2013, 03:55 PM   #365
pos is offline pos  Europe
pos's Avatar
Thank you Pano, but don't worry: I think I will do as more10 suggests and just reopen a new thread, in the software section
A new version is on its way, with several new PEQ implementations (among which the standard constant Q and proportional Q) and the choice to do minimum phase EQ.
This should now be easier to replicated EQ from other systems. For example Hypex DSP, the DCX2496 and most other processors use constant Q, whereas miniDSP and a few others use proportional Q.
Current EQ implementation was a different implementation (based on butterworth filters), and will still be available and probably called "coherent Q"
Old 29th January 2013, 12:40 PM   #366
Barleywater is offline Barleywater  United States
Above is demonstration of design process and choice, previously you review my IR data, and comment about pre-ringing. Above shows that I could easily follow path that produces speaker stamping out causal impulse type response. Measured result follows design choice for linear phase, and is easy to see when high frequency clutter is filtered from result:
Unfiltered IR of corrected system:
With application of FIR 4kHz low pass the above becomes:
Very much the predicted result.
Microphone at 23cm may be thought of as virtual source. All energy passing through this point from drivers continues radiating outwards in cone with identical wavefront as direct sound.
Yes, small regularization parameters request Kirkeby to seek more convergent solution. As Fourier system, the longer in time, the higher the frequency resolution. Properly used, inverses produced are highly exacting.
Sync function from time domain construction of Farina's sweep remains. The raw sweep and inverse generated by time reversal and amplitude envelope to get flat FR when convolved produce 2x long sync function with rectangular window. Farina's fading/windowing functions constrain/compact result, but always leave sync residue.
Original Aurora plugins include MLS.
I build my own sweep pairs using Kirkeby, or use REW or HOLMImpulse. HOLM allows for convenient export of sweep and inverse, allowing independent use and performance verification. HOLM passes. REW doesn't have inverse export, but digital loopback measurement verifies proper behavior.
Audacity does math very well, but GUI and feature set pales to Cool Edit. I've worked with Farina versions, Convolver and Kirkeby behave nicely as ever, and sweep generator still is flawed. Nonetheless, I've downloaded Audacity 2.0.0 and Farina's modules for it, and all is well on XP based system.
Indeed, major league OT on the one hand, but highly pertinent to measurement and modification of system response.
I search forum for "Kirkeby", "Convolution", "Aurora", and "Audacity" and see that starting a thread under "Software Tools" makes sense, perhaps, "Aurora Audacity, measurement synthesis and IR inversion"
Old 29th January 2013, 12:49 PM   #367
Pano's Avatar
Cool - good idea. Be sure to put a link back to this thread, and we can put a link to your new software thread at thetop of this thread.
Take the Speaker Voltage Test!
Old 29th January 2013, 09:06 PM   #368
pos's Avatar
I don't have much time to open that new thread (and change the links) just now, so here is the new version announcement for rePhase 0.9.3
Download: rePhase on sourceforge
Code:
0.9.3  2013-01-29
    - new Paragraphic EQ implementation, with multiple EQ types:
        * constant Q minimum-phase (new default)
        * constant Q linear-phase
        * proportional Q minimum-phase
        * proportional Q linear-phase
        * constant slope linear-phase (former implementation)
        * raised cosine linear-phase (beta version...)
      ( bank EQ section remains constant slope linear-phase )
    - FFT size can now be set by user (minimum size is two times the
      smallest power of two equal or bigger than the requested number
      of taps). Setting a larger FFT size makes generation and optimization
      slower, but can increase the precision of the optimization and also
      makes result curves more precise (just a visual effect for that one
      though: no effect on the actual impulse)
    - bug correction: negative gains can now be entered directly from
      the keybord in the Gain EQ Bank tab.
    - exit on repeted errors to avoid "panic mode" effect
Old 29th January 2013, 11:21 PM   #369
pos's Avatar
oups, forgot one last bug, a small but annoying one
rePhase 0.9.31 now online
Code:
0.9.31 2013-01-29
    - mini bugfix for the taps entry...
Old 31st January 2013, 12:36 AM   #370
Attachment 327011
Attachment 327012
Du.uuh! The "HF clutter" is causal so definitely due to the speaker/system. Are you saying your EQ doesn't work above 4kHz?
This is HUGE assumption. You may like to ask Prof Farina's opinion of this.
Didn't you say you had a swept sine system which also didn't give a resultant sync function?
What his wrong with Angelo's generator?
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
