And Now For Something REALLY BIG - Page 78 - diyAudio
Old 15th January 2013, 04:14 AM   #771
JRKO's Avatar
Send a message via AIM to JRKO
I wondered the same thing.
Apparently the individual cells become 'sources' themselves and thus the number of cells aids dispersion of the sound over the near and far field in a way the whole shell would not.
My issue with papier mache will be soggyness if I dont use card as the initial inside layer. Will start today on a rough pair - one with card liner and one of paper only.
pix to follow
If I'm not making noise, I'm making something to make noise
Old 15th January 2013, 05:02 AM   #772
GM is offline GM  United States
GM's Avatar
I've done this and no, it won't perform the same in the HF plus there's a difference between whether you clone the shell of a tar or non tar filled version as to whether it will perform the same down low. In concept, the WE/Altec 329A horn is ~ the shell of a 1005B, so gives some idea of what to expect, i.e. a traditional rising on axis response like the 511, 811 horns.
I chose the wave guide [conical] shape of the tar filled and once I got it figured out somewhat, it convinced me that this was the way to get high SQ out of a compression horn, though at the cost of it needing to be a lot bigger for the same LF corner, i.e. a ~1803 size to get a solid 500 Hz using an 802D.
This hurt the HF output too much due to the strong mouth reflections back to the throat, so wound up with an ugly foam horn extension initially and ultimately a very large round-over extension that made the LF/HF horn c-t-c spacing audibly unacceptable at my ~16 ft listening distance.
To get the 'full' mids of the big horns and the HF of the 'small' horns, I finally 'settled' for dual stacked 511s with one rolled off. Once damped, I found I liked this better in my app than an EQ’d multi-cell, though not as much as the huge WG. ‘BIB’ rules!
All things considered then, following the profile of a non tar fill 1505 and limiting it to 4-5 kHz seems worth trying and with today’s digital delay, placing a small super tweeter horn inside to cover the top two octaves could make for an impressive combo.
Better yet, an 1803 tar filled shell with super tweeter horn.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th January 2013, 05:24 AM   #773
JRKO's Avatar
Morning GM. So do you not believe the papier mache/card endeavour will work? Or are you just saying you prefer sectoral to multicell?
Old 15th January 2013, 05:45 AM   #774
GM's Avatar
A late night here.
I see no reason why not assuming you plan to make a multi-cell and not just a shell as I did, otherwise you'll have the same set of trade-offs to deal with.
WRT multi-cell Vs sectoral, it mostly comes down to how wide a 'sweet spot' and HF response is desired, so is very dependent on the room, system and of course, personal preference.
Personally, the sectoral is at the bottom of my list for high SQ as there's no way to get around its inherent 'horniness' without using a high enough XO point to turn it into basically a HF WG.
GM
Old 15th January 2013, 11:57 AM   #775
JRKO's Avatar
REALLY stupid question.
Vol pot goes inline with the incoming line signal then lpads on the outgoing speaker level signal? Combined stereo pot/lpad ok for both applications?
Old 15th January 2013, 02:03 PM   #776
JRKO's Avatar
scrap the last bit about stereo lpads.......as per Pano's words above.
Question. When looking for pot for ACA ZM said "btw - if you're feeding just one way with ACA , L-pads are redundant (and bad for sound) , having pot in front of ACA" and "if you have pot in front of ACA , you don't need attenuation right in front of driver. Any sort of L-padding ( variable or fixed ) will kill the grunt. Try , listen and then decide"
I was confused about having vol pot AND Lpad and now more so
Old 15th January 2013, 03:21 PM   #777
buzzforb's Avatar
Assuming you have two identical amps feeding horn and woofer, you of course need some way of adjusting levels to get the two to match. This can be done before or after amp, or both. You could level it after amp and all is good, if you have identical gain structure feeding both high and low. If you have mismatched amps and, as a result, mismatched gain, then you need to be able to adjust the amps accordingly. This would be done with pot on front. I think either will work fine, but I do get the idea of having it adjusted before the amps get involved.
...Shape the sound , Man!
Old 15th January 2013, 03:27 PM   #778
JRKO's Avatar
I'm with you on that buzz.
Originally Posted by Pano View Post
...Horns are very efficient. That means all the hiss, hum, buzz, rizz, etc. that you don't notice on normal speakers will be plenty obvious on the horns. Dropping the horn's level 6-12dB will get the amp's output up out of the dirt. Yes, you'll need more power, but that's rarely a problem in domestic settings.
I think I get Pano's statement above. reducing the ACA speaker level output via Lpad's allows more volume to be used getting the amp into the clean fresh air of up to 5W.
As its a Nelson Pass SE will it be dirty low down? (not not like that )
Old 15th January 2013, 03:49 PM   #779
buzzforb's Avatar
Don't forget that all important FW. With horns, I doubt you will see much more than that on any regular basis, but I do understand his thinking.
Old 15th January 2013, 05:46 PM   #780
JRKO's Avatar
Yeah and that all important FW is fro ma table on a vineyard in California.
I hate that FW.....
I got this pot: 500K Tocos Cosmos RV24 Stereo Potentiometer Hifi Collective over the Alps blue beauty and lesser than the Nobles & TKD's
I'm gonna cut card sides x 4 tomorrow. 1 will let me cut paper to shape and then will join the others to form the basis of a horn. Papier Mache will fill the voide from front to rear lip left by the curve - thats the plan anyhoo
The paper will be a build up of similar shapes getting smaller so fill the void leaving the ends a couple of thicknesses but more in the deeper middle - again, thats the plan anyhoo
Transformers: How big is TO big?? dfdye Power Supplies 39 4th September 2010 02:30 PM
Big Toroids & Big Caps K-amps Swap Meet 10 25th June 2009 07:43 PM
Having problems with port size... how big is far too big? fjhuerta Multi-Way 10 30th August 2005 06:20 PM
Big Big hum ??? vlljpior Tubes / Valves 4 26th August 2005 03:53 AM
Copyright ©1999-2017 diyAudio
